Powerdynamo question
For non German-speakers. We will try to discuss in your language here, preferably in English. Guest posts welcome.
Beitragvon madmog » 5. April 2018 20:59
I'm about to wire in a Powerdynamo on my ETZ250. Two questions:
Is it worth wiring a large diode in series to prevent accidental mis-wiring of + and - of the battery in future? Ie something to idiot-proof replacing the battery in a few years or tinkering with the electrics and accidentally short something? Is one diode enough or something more somewhere to protect the delicate circuitry?
Secondly, what's the estimated life of the Powerdynamo - are there any spares (of the Powerdynamo bits) worth carrying if touring or is that not necessary?
Thanks
Fuhrpark: MZ ETZ250; Vespa P200; LML Star
madmog
Re: Powerdynamo question
Beitragvon der garst » 6. April 2018 03:23
Regular there will be no support for Powerdynamo by the MZ-Forum, because of some differences inbetween.
I am sure Edgar from PD will answer your questions if you write or phone him.
Beitragvon madmog » 6. April 2018 10:53
der garst hat geschrieben:Regular there will be no support for Powerdynamo by the MZ-Forum, because of some differences inbetween.
Thank you
madmog
Beitragvon mario1300 » 26. Juni 2019 11:04
Hi guys.
I have a question about timing of Vape powerdynamo ignition:
borowed image:
How many of you are driving with ignition timing as recommended ( 2,75 mm to 3,00 mm before top dead center)??
Current ignition timing on my ES 250/2 is 2 mm and if I retard it to 2.75 mm as recommended the motorcycle loses performance :evil:
Fuel today has higher octane rating then in the past(The higher the octane number, the more compression the fuel can withstand before detonating (igniting).
Maybe this was the reason why old mz ignitions had to be adjusted to 2,75 mm to 3,00 mm btdc and nowdays because of higher octane fuel the ignition should be more˝in advance˝(less than 2.75mm btdc) ??
give me your thoughts and experience
Fuhrpark: MZ ES 250/2
mario1300
Beitragvon hiha » 26. Juni 2019 11:24
mario1300 hat geschrieben:(The higher the octane number, the more compression the fuel can withstand before detonating (igniting).
That's not completely true, especially not in a two-stroke-engine, and not for nowadays pump-fuel.
Next thing: If you were right, you could adjust MORE pre-ignition than with low-octane-fuel.
Did you ever use a stroboscope, to look what ignition-timing you have in reality? My TS250-1-engine is running perfectly with 2,75mm bdtc, so I suppose a adjustment-problem.
Cheers,
Hans
hiha
Beitragvon mario1300 » 26. Juni 2019 11:51
Thanks for reply Hans.
I havent´t tried it with stroboscope jet...
But...correct me if I am wrong:
The stroboscope pistol/light will only tell me if the spark happens at the moment when line/marking on stator and rotor align?
The ignition can still be at 1.5 mm bdtc or at 3mm bdtc / it will not tell me what is the best position for engine?
mario1300
Beitragvon Guesi » 1. Juli 2019 06:12
You can put your own marking on the base plate of the powerdynamo to check if the ignition timing is correct. For example the 2,75 mm and the stroboscope will tell you if the timing corresponds with the marking...
GüSi
GüSi Motorradteile
Fuhrpark: diverse
Guesi
Beitragvon hiha » 1. Juli 2019 06:58
Sorry, didn't read here since.
Like Güsi said: Measure and mark your own marks, then you will know...
Hans
hiha
Beitragvon mario1300 » 8. Juli 2019 11:47
Thanks for answers
mario1300
Zurück zu Questions and Answers
