ES 250 Mag-Dynamo
For non German-speakers. We will try to discuss in your language here, preferably in English. Guest posts welcome.
ES 250 Mag-Dynamo
Beitragvon traderyoda » 27. Juli 2022 02:03
Greetings,
Does anyone know how to locate for purchase a mag-dynamo for the ES 250 motor? These were fitted on some motors, like the G-5 ISDT models (and possibly others) around 1970. I've attached some photos of this unit.
Thank you.
Grüße,
Weiß jemand, wie man einen Mag-Dynamo für den ES 250-Motor zum Kauf findet? Diese wurden um 1970 an einigen Motoren angebracht, wie den G-5 ISDT-Modellen (und möglicherweise anderen). Ich habe einige Fotos dieser Einheit beigefügt.
Vielen Dank.
Dateianhänge
Pictures of MagDyno.pdf
(387.72 KiB) 681-mal heruntergeladen
Fuhrpark: ES250/1969
traderyoda
Re: ES 250 Mag-Dynamo
Beitragvon ets_g » 27. Juli 2022 09:05
The KLZ magdyno was only fitted on the later ETS/G. You can find them sometimes on ebay or ebay Keinanzeigen. Maybe he https://trophy-sport.de/ can help you. But as far as i know the KLZ will not fit on the battery ignition crankshaft. The cone is different and also the engine cases.. https://www.powerdynamo.biz/deu/systems ... _nicht.htm
powedynamo has made magdyno systems for the battery type but the company is closed. Vape has different systems for sale, i think this https://www.vape.eu/de/mz-ets250g could be right for your engine. They have also replacement for the KLZ type, but you have to check what is the right system for your engine.
I would always prefer the Vape, I had the KLZ fitted on my ETS/G and it ´didn´t work very well. Maybe because of the age, i don´t know.
Fuhrpark: MZ ETS/G 1967
MZ ETS/G 1970
ets_g
Beitragvon traderyoda » 28. Juli 2022 15:31
ets_g hat geschrieben:The KLZ magdyno was only fitted on the later ETS/G. You can find them sometimes on ebay or ebay Keinanzeigen. Maybe he https://trophy-sport.de/ can help you. But as far as i know the KLZ will not fit on the battery ignition crankshaft. The cone is different and also the engine cases.. https://www.powerdynamo.biz/deu/systems ... _nicht.htm
Many thanks for this information. It makes clear that the KLZ mag-dynamo fits to a different crank end so no need to search for this option. I was not aware that Vape had a 6v/18W simplified systems for the older ES 250G motors. It looks pretty interesting and I will investigate it further. Thanks for letting me know!!
traderyoda
Zurück zu Questions and Answers
Loading...
