k650 hat geschrieben:I took my totaly restored ETZ251 for a testride today for the first time and i runned perfekt, but one thing i noticed was that i think my TS250/1 has better power than the ETZ251. Anyone else that has same experience between the models?
Norbert hat geschrieben:k650 hat geschrieben:I took my totaly restored ETZ251 for a testride today for the first time and i runned perfekt, but one thing i noticed was that i think my TS250/1 has better power than the ETZ251. Anyone else that has same experience between the models?
the Difference can you see when you lay the Diagram of Power and Torque over the other.
The TS engine runs and shows Power from about 2000 rpm , the ETZ engine from about 3000rpm
(serial conditions each).
In the Result the driveability of the TS is much better than from the ETZ.
The Difference in the Frameworks is that the TS is made from solid Pipes, the ETZ frame is only
a thin tincan.
Maybe that the ETZ Frame ist better when it is stressed by vertikal inpact.
But it is really helpless by horizontal inpact.
The ETZ Frames are a reaction to/from the economical pressure in GDR.
