To get stronger shock absorbers, the direction of rotation should be clockwise at left- and otherwise at right sight.Ratzifatzi hat geschrieben:Check that the lever to adjust the force of the spring works to the outerside. If you assemble them in a wrong way, you have to turn the lever closer to the wheel.
[/ot]Zurück zu Fahrwerk - Rotax (500ccm)
