MZ es175/1 shock absorber oil
Kraftstoff, Gemisch, Öle.
Beitragvon mexec » 20. Mai 2007 14:23
MZ es175/1 shock absorber for which oil to use necessary or which number oil ? castrol -- shell- mobil ???
( 80 cm3 Stoßdämpferöl 'Globo' je Federbein, Viskosität 1,65 ... 1,92°E bei 50°C = 8 ... 11 cSt/50°C
Im Ausland nur Marken-Dämpfungsflüssigkeit mit gleicher Viskosität verwenden! )
thanks.
1964 MZ es175/1
mexec
Beitragvon alexander » 20. Mai 2007 15:30
Ich uebersetzte das mal (sinngemaess):
Fuer ne es 175/ 1 ist gefragt nach dem richtigen/ benoetigten Stossdaempferoel. .... .
Zeltphilosoph
Themen: 73
Beitragvon mexec » 22. Mai 2007 16:03
this in feature another which type alternative oil useable ? shell or castrol or mobil ......???
1964 MZ es175/1
mexec
Beitragvon Ex User Hermann » 22. Mai 2007 16:11
mexec hat geschrieben:this in feature another which type alternative oil useable ? shell or castrol or mobil ......???
SAE 10 - SAE 15 "Fork-Oil"
Ex User Hermann
Beitragvon alexander » 22. Mai 2007 21:43
Hermann hat geschrieben:
@ MEXEC:
That means you can use oil from any manufacturer or supplier as lon sa the specification is FORK OIL with viscosity SAE 10 to SAE 15.
Doesn´t matter if SHELL, PENNZOIL, GULF. Everything will do the job.
Zeltphilosoph
Themen: 73
Beitragvon mexec » 23. Mai 2007 09:59
1964 MZ es175/1
mexec
Beitragvon eichy » 23. Mai 2007 16:06
I try my best:
Its not so important from which factory the forkoil comes. More important ist, that you use a SAE10-SAE15 Oil as Hermann writes.
eichy
Beitragvon alexander » 23. Mai 2007 22:21
Hi Mexec,
first thre links are o.k.
Forth link I can´ t translate. Although living in "little Anatoly" here in west- Berlin I´m not able spaeking or reading one turkish word.
So take one of the first ones and remark the higher the viskositynumber the thicker the oil will be. Means the tougher the fork will be.
Try one and you will see what happens.
Be brave, don´t tarry.
Go to your lokal forkoildealer, by a pack, put it into the fork, fasten the catch.
Then ignition, kick, and rush.
Good luck
Zeltphilosoph
Themen: 73
Beitragvon mexec » 25. Mai 2007 15:49
eichy hat geschrieben:I try my best:
alexander hat geschrieben:Hi Mexec,
Good luck
Thanks :gut:
1964 MZ es175/1
mexec
Zurück zu Betriebsmittel
