 Betreff des Beitrags: Pannier Frames/Gepäckträger/Seitengepäckträge for Mz Country
BeitragVerfasst: 20. März 2013 09:20
Hello, can anyone supply me with pictures as to how pannier frames would fix to an Mz Country. Is there anywhere to buy these pannier frames? Also did the Mz Country come with Bilstein rear shocks as standard? Thanks.
 Betreff des Beitrags: Re: Pannier Frames for Mz Country
BeitragVerfasst: 20. März 2013 09:30
Hello,
the original one should be Hepco&Becker http://neu.hepco-becker.de/Montageanlei ... 3.0001.pdf
to buy at Polo http://www.polo-motorrad.de/de/seitentr ... y-500.html
BeitragVerfasst: 20. März 2013 09:44
Hi and thanks for the reply, is there anyone who could translate this pdf http://neu.hepco-becker.de/Montageanlei ... 3.0001.pdf
BeitragVerfasst: 20. März 2013 09:49
what information do you need?
the complete text? it's only the assambly instruction.
BeitragVerfasst: 20. März 2013 09:57
I was hoping it would give me the mounting points for the frame. I already have Hepco frames and panniers that i was hoping to modify and make fit.
BeitragVerfasst: 20. März 2013 10:00
ah okay.
maybe some of the country owner can make pictures.
in a free minute I'll translate some facts of the mounting descriptions :ja:
-- Hinzugefügt: 20/3/2013, 10:28 --
I searched for some pictures but didn't find some good ones.
but while looking at them viewtopic.php?p=863309#p863309 I saw the mounting points, I think.
remount the seat and the cover below it.
then you see the frame and different holes. one is for the shocks. the others are for the panniers.
on the rear end of the frame it's similar. the free holes are for the pannier, the others should be used by the back handle.
the other mounting points are on the passangers footrests and on the backside of the fender.
the picture in the pdf shows it a little bit.
BeitragVerfasst: 20. März 2013 10:32
brennain1 hat geschrieben:
Yes, they did...
BeitragVerfasst: 20. März 2013 11:46
Hi Chris, yes I think I can see the mounting points in the pictures. In the 1st picture there are 2 tubes looking down just to the rear of the crossmember, i'm assuming that these could be the rear mounting points?
Hi Gerd, did the Country also come with a tool kit and where was it stored, also what did it contain? Mine as far as I can see doesn't have one.
 Betreff des Beitrags: Re: Pannier Frames/Gepäckträger/Seitengepäckträge for Mz Cou
BeitragVerfasst: 20. März 2013 12:05
Thema verschoben und ergänzt
BeitragVerfasst: 20. März 2013 12:16
thanks, achim :)
BeitragVerfasst: 20. März 2013 16:31
I have used ones to sell, need some paint.
BeitragVerfasst: 21. März 2013 21:02
Nordtax hat geschrieben:
Hello Nordtax, have PM'd you.
