Aktuelle Zeit: 10. April 2026 18:04
 Betreff des Beitrags: Rear Wheel Needed....Found !
BeitragVerfasst: 21. Mai 2015 02:53
A man from england is offering an rear aluminum wheel from
a ts250/1 for a cost of £20, plus shipping......
Will it fit a ts250/0 ?
Thanks,
M
Fuhrpark: MZTS250/0,
Yamaha Standard 1100
Zuletzt geändert von MichaelTorre am 25. Juni 2015 05:22, insgesamt 2-mal geändert.
Mit Zitat antworten
 Betreff des Beitrags: Re: Rear Wheel Needed
BeitragVerfasst: 21. Mai 2015 07:24
Artikel: 3
Themen: 153
Yes it should fit. But a photo would help...
GüSi
GüSi Motorradteile
Fuhrpark: diverse
Mit Zitat antworten
BeitragVerfasst: 21. Mai 2015 10:35
If it is real from a TS 250/1, then it will fit.
And you´ll get a better brake ring in the hub, the brake ring in the TS 250/0 has a cut and is only pressed in the hub. This sometimes cares for a trouble. The brake ring in the hub of the TS 250/1 is casted in the aluminium (in german: "alferiert", it means a special procedure to link aluminium + ferrum/iron).
Mit Zitat antworten
BeitragVerfasst: 21. Mai 2015 17:13
http://m.ebay.co.uk/itm/161702425077?nav=SEARCH
Hope the link works.
Got the wheel finally on 22/6/15. from that gentleman.
He took the tire off, and kept the brake hub at my request
to get the shipping down to a reasonable amount.
In nice shape and I feel fortunate to have it.
As an aside the new brake shoes bite VERY well on this bike.
(Thank you Guesi)
M
Mit Zitat antworten
BeitragVerfasst: 21. Mai 2015 17:44
match
MfG Jens
Mit Zitat antworten
Du darfst neue Themen in diesem Forum erstellen.
Du darfst Antworten zu Themen in diesem Forum erstellen.
