 Betreff des Beitrags: ES 250/2 with Ts 250/1 5 speed engine
BeitragVerfasst: 19. Juli 2015 22:18
Hi guys.
On this forum there are a few REALLY interesting topics about installing a TS 250/1 5 speed engine into/on ES 250/2 body.
Also there is topic about cons and pros of 4 speed (es 250/2 or ts 250/0) and 5 speed ( ts 250/1).
Since my german is bad,and my translator does not always translate everything so I can understand it; I have a few questions... :roll:
Is it worth to install 5 speed engine on es 250/2 WITHOUT trailor?
Would the max speed increase?The fuel consumption should be lower at higher km/h?Crousing speed would increase?
Which gearbox or engine is more durable? 4 speed or 5 speed? Some cons and pros on english please :oops:
Thanks for answer :twisted:
Mit Zitat antworten
 Betreff des Beitrags: Re: ES 250/2 with Ts 250/1 5 speed engine
BeitragVerfasst: 20. Juli 2015 15:32
mario1300 hat geschrieben:
:gruebel: What is a trailor, with reference to a motorcycle? I only know these trailors: http://www.otozhaf.com/automobiles/2014 ... 25952.html
Mit Zitat antworten
BeitragVerfasst: 20. Juli 2015 17:05
My Englisch ist bad, lock at the Pictures of my 5Speed TS Engin in a ES250/2.
Dateianhänge:
Click to view small - view big
SANY0024.JPG [ 15125-mal betrachtet ]
SANY0021.JPG [ 15125-mal betrachtet ]
SANY0023.JPG [ 15125-mal betrachtet ]
SANY0022.JPG [ 15123-mal betrachtet ]
Mit Zitat antworten
BeitragVerfasst: 20. Juli 2015 19:27
The benefit of a 5 speed engine is the easier maintenance compared to a 4 speed engine. You can change the shaft seal rings of the 5 speed engine without a complete disassembly of the motor.
Mit Zitat antworten
BeitragVerfasst: 20. Juli 2015 19:31
And the 5 speed engine is better for sidecar use.
The maximal speed ist equal to the 4 gear speed engine.
Mit Zitat antworten
BeitragVerfasst: 20. Juli 2015 23:48
Thank you for your answers :mrgreen:
Ok,I meant a sidecar,not a trailor :tongue:
Crusing speed should increase also with 5 gear gearbox...
On my ES 250/2 I consider good crusing speed at about 80-90 km/h in 4.gear(relativly low rpm)
While according to this dyno test:
https://www.youtube.com/watch?v=wARI-RN ... =BazsiKing
TS 250/1 should have a good crusing speed at about 90-100 km/h
Mit Zitat antworten
BeitragVerfasst: 21. Juli 2015 07:16
80 km/h as average speed is o.k. for a sidecar.90-100 km/h is the top speed under optimal conditions.
Even with the 250/1 engine this should not be more.
And by the way, I remember that Croatia is not flat. You have some mountains :-)
So the good thing about the 5 gear engine is not the speed, but the better handling in non-flat areas.....
Mit Zitat antworten
BeitragVerfasst: 21. Juli 2015 10:04
Yes,Croatia has a little bit of everything ;)
Thanks for answer :)
Mit Zitat antworten
BeitragVerfasst: 19. September 2015 20:07
If you find you are going 110 to 120 kph should you back off ?
Is one in danger of causing damage running this hard ?
M-
-- Hinzugefügt: 19. September 2015 14:07 --
M-
Mit Zitat antworten
