Aktuelle Zeit: 4. April 2026 05:32
 Betreff des Beitrags: Seeking Compromise
BeitragVerfasst: 23. September 2018 15:14
I have 1974 TS 250 / 0.
Where I live I drive quite a bit in the 64kph to 75 kph range.
As you well know this is not a good speed for some of the 4-speed M Z's. To compound this difficulty it is very hilly terrain where we live now.
My question is, would it be useful to go to one tooth smaller sprocket on the front to get more drivability in this speed range.
I rarely ever have to go over 96 kph.
Best regards,
Michael in Virginia
Fuhrpark: MZTS250/0,
Yamaha Standard 1100
Mit Zitat antworten
 Betreff des Beitrags: Re: Seeking Compromise
BeitragVerfasst: 23. September 2018 15:32
Hello Michael!
Of course it is possible to change the sprocket. I did this on my ETZ (5-speed) and now I can use the fifth gear on rural roads.
But you have to consider that you need a sprocket for the 4-speed engines, which has another width than the ones for 5-speed engines.
Mit Zitat antworten
BeitragVerfasst: 25. September 2018 15:46
My question is. Is it a good idea or will I not realize the gains that I seek in the 64 to 75 km speed range ??
M.
Mit Zitat antworten
BeitragVerfasst: 25. September 2018 17:37
hi -
i run my four speed es 250/2 on a smaller sprocket. 65 - 75 never felt 'wrong' in any way ...
why not try it out, might as well tick your boxes.
max ~:)
http://www.alteisentreiber.de
Mit Zitat antworten
BeitragVerfasst: 25. September 2018 18:14
TS 250 mit 4Gang-Getriebe hat ein 21er Ritzel. Versuche ein 20er Ritzel. :ja:
Mit Zitat antworten
BeitragVerfasst: 25. September 2018 19:19
Hello, a gear with 20 teeth could fit well. As already mentioned pay attention to the 4-speed version.
Mit Zitat antworten
BeitragVerfasst: 26. September 2018 00:00
I love the change.
It has been a great adjustment.
There has been no perceived detriment to the top speed of the motorcycle. But then again the authorities are very very strict about high-speed driving in the Old Dominion of Virginia.
So no flat-out out chest on the fuel tank high speed runs like I did in Missouri.
This bike TS250/0, is better suited to the mountains rather than the open Plains
M.
Dateianhänge:
Dateikommentar: Open Prarie
20170506_144642.jpg [ 248.43 KiB | 11519-mal betrachtet ]
Mit Zitat antworten
Du darfst neue Themen in diesem Forum erstellen.
Du darfst Antworten zu Themen in diesem Forum erstellen.
