Battery not charging! Help desperately needed please!
Beitragvon Numptywizz » 1. März 2020 14:02
Good morning everybody!
I have a very frustrating problem with my 1954 IFA RT125/1 and I am hoping somebody can help!........
When the engine is running, the charging light (red) will not go out and only goes slightly dimmer if the engine is revved highly. I have a regler RT125 (D+) from Moped-Werner.de fitted and I have double checked all the wiring and all seems correct. When the engine is running the generator (Lima 45w) is only giving 1-3 volts and I think this should be higher!
This is all that is stopping me from enjoying riding my RT and I am desperate to fix, so any help and advice will be very much appreciated!
Many thanks and kind regards, Neil
Fuhrpark: 1954 RT125/1, 1955 BK350, 1960 IWL SR59 Berlin, 1960 IWL Campi, 1976 TS250, 1977 TS250, 1994 HD MT500, 2000 Yamaha YP250, 2002 HD Sportster, 2015 HD Roadglide Special
Numptywizz
Re: Battery not charging! Help desperately needed please!
Beitragvon Tourgigant » 1. März 2020 14:18
Hi Neil,
One picture is worth 1000 words.
So maybe this clip is worth hundred thousand words.
It has englisch subtitles.
https://youtu.be/EYr1rBDSIqM
Greez,
Fuhrpark: MZ ES 150 - 1965
MZ TS 250/1 - 1980 - ABV
Suzuki GN 125 - 1997
Tourgigant
Beitragvon Numptywizz » 1. März 2020 14:35
Many thanks Andreas! hopefully this will help!
Kind regards, Neil
-- Hinzugefügt: 1. March 2020 14:21 --
Hi Andreas
I've done the first part (DF and D+ together and earth) and I've only got approximately 5-6 volts, so I think my generator may be the problem?
Regards, Neil
Numptywizz
Beitragvon flotter 3er » 1. März 2020 17:58
Hi Neil, if you have measured everything correctly and the measurement at the generator only delivers 5 - 6 volts, then here is the problem.
Beitragvon Numptywizz » 2. März 2020 18:11
Hi Frank
Yes indeed! I think my generator is faulty (I've got a spare one from an IWL Berlin, hopefully I can use that!
Kind regards, Neil
Numptywizz
Beitragvon Tourgigant » 3. März 2020 23:09
Hi Neil,
Since no one seems to be willing to spend another 1000 words on changing the generator, here’ s is another video on that issue. ?
And don’t miss part 2!
https://youtu.be/p_aBfxFOUAo
Best regards,
Tourgigant
Beitragvon Numptywizz » 19. März 2020 21:44
Hi there Tourgigant
Many thanks for the information! This will be very useful (especially as my friend has an ES 125/1!)
Kind regards, Neil
Numptywizz
Mitglieder in diesem Forum: ftr und 9 Gäste
