TS250/0, ES SE pictures wanted.
Beitragvon Lasse » 18. Mai 2009 21:42
Hi!
I have an ES superelastik and a TS250/0 which I want to mount together.
I would like all the pictures you can provide, I have got it as a basketcase, so anything is appreciated.
Especially from the brakingsystem.
Thanks!
Fuhrpark: MZ ES250/2 1968
Yamaha XS650 1976
Lasse
Themen: 71
Re: TS250/0, ES SE pictures wanted.
Beitragvon TS Jens » 18. Mai 2009 21:50
In the Year 1976 was the TS 250/1 make in the factory in Zschopau.The TS 250/0 was make from 1973-1975 ??
Repair books are on this site.
http://www.mz-b.de/miraculis/aw/mz/mz.h ... zlink.html
under Bücher
Gruß Jens
MZ 500 R
TS Jens
Beitragvon Lasse » 18. Mai 2009 21:59
It's a 76 according to my registrationpapers, it is a /0.
16" inch wheels, speedometer in the headlight etc.
I've seen those pictures before, but I can't see how it actually goes on to the frame, the braking system, I am unable to visualize it. If you know what I mean?
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon TS Jens » 18. Mai 2009 22:04
Need you pictures from the superelastic brake our pictures from the up/down motorcycle brake ?
MZ 500 R
TS Jens
Beitragvon Lasse » 18. Mai 2009 22:12
From the brakepedal to the wheel would be optimal, I can't figure out how it is put together, also I don't know if I have all the parts.
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon TS Jens » 18. Mai 2009 22:30
Hallo hat hier jemand im Forum ein Foto vom Bremsgestänge einer TS mit Seitenwagen?
Ich kann nur Fotos von einer Solo TS machen.
MZ 500 R
TS Jens
Beitragvon Vinc » 19. Mai 2009 11:52
HI Lasse,
Mayby its not possible to mounth the Sidecar on the frame of your TS-250/0 because the first version of the /0 is not stable enough for Sidecars. I have a TS250/0 from 1973 this Frame is really flexible and not very stable, i never would drive it with Sidecar. The Gable is also not very stable! Do you have the 3 Plugs for the Superelastic Sidecar on your Frame (than its OK)? At least the Version from 1974 is OK for Sidecardriving, but better is a the TS250/1. If you have a Version befor 1974 with the first Frame i would never try it because its very Dangerous!
Please excuse my bad english, i hope yopu can understand and it was helpfull.
Cheers Vinc
Es geht hier nicht um "zu schnell" es geht ums Fahren...
Fuhrpark: Tatra 613 3,5L V8 1977
Honda CB 900 Boldor 1981
Suzuki GSX 750 e 1980
Suzuki GT 750 (Wasserbüffel) 1975 (Caferacer)
Honda CX 500 Güllepumen Gespann mit Velorex 700 Boot 1981 (Reisefahrzeug)
MZ ES 250/2 Gespann 1968 (Das Alltagsfahrzeug)
Simson S50 1973 (für alle Fälle)
Vinc
Beitragvon Lasse » 19. Mai 2009 12:57
How do I determine that? I have an ETZ front fork for it for discbrake. It is one of the last /0's, 1976 from the papers.
This machine has been driving with a sidecar on it for about 25 years until I bought it, I figure it should be fine :)
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon zweitaktschraubaer » 19. Mai 2009 13:29
regarding the difference between the early /0´s and the late ones:
The early ones did not have the straight tube rectangular to the driving direction below the front end of the seat.
That tube is necessary to install the upper attachment point for the sidecar - which is nothing but a big bolt with a ball-end.
If you have that tube everything is fine, don´t worry about the stability. :)
For the attachment of the sidecar generally you need these parts:
- upper attachment bolt,
- attachment bracket with the fwd attachment ball
- an axis with a ball-end for the swing arm
- the swing arm with the attachment for the stabiliser.
Not mandatory but recommended:
Steering damper
But I think if that machine has already run as a sidecar machine, everything should be all right. :wink:
If you use the ETZ fork with the disc brake:
Either you use the ETZ clamping heads or maybe you will have to use a spacer to center the wheel again
- the TS clamping heads have a different distance between the fork legs.
As the sidecar had been mounted to an ES model before:
Check if the forward attachment strut is the correct one. See also: kb.php?a=124 , there are the different types listed.
Good luck and have fun!
By the way: If you want you could perhaps keep us informed about your project.
And we always do like pictures...
:mrgreen:
Regards
Jan
Suche dringend: Mehr Freizeit
Fuhrpark: Englische, französische und deutsche Zweiräder von 50 bis 600 ccm...
Und ein Bakfiets.
zweitaktschraubaer
Beitragvon Lasse » 19. Mai 2009 13:33
Great answer, thanks!
Saw that link yesterday, will have to measure that when I get back home.
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon Vinc » 19. Mai 2009 14:23
Yes thats great! The TS from 1976 is OK. With the ETZ Fork its very stable. If it was running as Sidecarmashine for years than really all should be fine! I did not know that it is allready a complete Sidecarbike. I thought that you want du upgrade the Sidecar to a regular TS.....
Cheers Vinc
Vinc
Beitragvon Lasse » 19. Mai 2009 14:35
It doesn't have a sidecar now, it ran an old ACAP sidecar from the 30'es
See the special front frame
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon zweitaktschraubaer » 19. Mai 2009 14:48
Wow, that looks great!
Especially the specialised frame.
And the ETZ engine has got a lot of potential - especially when you install a 300cc cylinder... 8)
Regards
Jan
Und ein Bakfiets.
zweitaktschraubaer
Beitragvon Lasse » 19. Mai 2009 14:52
I am considering changing the brakesystem to cable operated.
Yamaha XS650 1976
Lasse
Themen: 71
