 Betreff des Beitrags: SilverStar Front Wheel Bearings
BeitragVerfasst: 6. November 2009 17:46
I installed new tires on the SilverStar and have a question about the front wheel loose ball bearings. In the picture (not my SilverStar but similar), under the grease, there are several loose ball bearings. Are the ball bearings packed in to completely fill the race? I have gaps between the bearings like some may be missing? I cleaned and re-packed everything with new grease and the wheel is straight and true woth no play. If I need new bearings, can I please have a part number or substitute source? I have SilverStar maintenance and part manuals coming soon, so I will not bother you with my silly questions too much in the future. Thanks you for all the help so far. I still love this SilverStar!
 Betreff des Beitrags: Re: SilverStar Front Wheel Bearings
BeitragVerfasst: 6. November 2009 21:17
Hello,
normaly you can find the number on the side of the bearings!
You can find a Silverstar Repairmanual in the Internet but now i don't know where you can find it in english ???
Bye
Simmetuner
BeitragVerfasst: 6. November 2009 21:52
Hello.
Please look here:
BeitragVerfasst: 6. November 2009 22:34
It is absolutely OK that the bearings have gaps between the balls. If the installed bearings are from the DKF company, you will find 7 balls in a bearing. Other bearings manufacturer have 8 balls in each bearing. The balls are fitted into a bearing cage and therefore there is no ball directly beside the next one.
BeitragVerfasst: 6. November 2009 23:34
Berni hat geschrieben:
It is absolutely OK that the bearings have gaps between the balls. If the bearings are installed from the DKF company, you will find 7 balls in a bearing. Other bearings manufacturer have 8 balls in each bearing. The balls are fitted into a bearing cage, and therefore there is no ball directly beside the next one.
You are the man Berni, and yes, I have balls with seven gaps (that sounds bad in English).
:mrgreen:
But I've been told that the replacement bearing is a sealed bearing 6302-2RS 15x42x13, here:
http://www.vxb.com/page/bearings/PROD/kit8050?gclid=CKTcgIqC950CFQRM5QodL1TvqQ
Is this correct? Danke
BeitragVerfasst: 6. November 2009 23:45
Hey Donny!
If the old bearings have the same four-digit number everything´s fine.
the appendix 2RS means nothing but that you have a tight seal on each bearing side - it keeps water outside and the grease clean.
If you´d use ...-2Z bearings you´d only have a protection against dust and dirt...
So, if the measures / the number is the right one you just need to install the 2RS bearings - and forget them.
And better try to avoid "No name"-bearings, recommendations are e.g. SKF or INA ones.
G´night!
Jan
By the by: Ahm, yes, I´ll better not write any comment on someone´s seven balls...
:mrgreen:
Zuletzt geändert von zweitaktschraubaer am 6. November 2009 23:47, insgesamt 1-mal geändert.
BeitragVerfasst: 6. November 2009 23:46
Donny hat geschrieben:
......., and yes, I have balls with seven gaps (that sounds bad in English).
:mrgreen:
That sounds strange in every language ... :oops:
Yes, that's correct Donny.
BeitragVerfasst: 7. November 2009 01:16
  Thanks Berni-san.
-- Hinzugefügt: 06.11.2009 19:28:58 --
[quote = "zweitaktschraubaer"] Hey Donny!
If the old bearings have the same four-digit number everything's fine.
the appendix clean 2RS means nothing but that you have a tight seal on each side bearing - it keeps water outside and the grease.
If you'd use ...- 2Z bearings'd only have a protection against dust and dirt ...
And better try to avoid "No name" bearings, recommendations are eg INA or SKF ones.
G'night!
January
By the by: Um, yes, I'll better not write any comment on someone's seven balls ...
  : mrgreen: [/ quote]
Thank you. I'm looking for the SKF nearings now. G'night mate!
