Teemu hat geschrieben:Hello!
I have to consider a total renewal of my ETZ 251 engine during the winter as I lost the third gear and the engine sounds as there are few bearings broke. How big operation is it to take the engine into parts totally? Do I need any special tools or is it possible to do with normal tools? As for now I have only renewed the clutch so it requires somewhat more work. I really hope to be able to do it during the winter.
I could buy a "new" engine but then the problem would be the local "TUV" here which is expencive and anyways I want to repair the original engine.
I assume that new parts for the engine can be bought at least from Germany if I am not able to find them locally.
Thanks already.
Teemu
eichy hat geschrieben:Da gabs doch mal englischsprachige Filme bei Youtube von MZ direkt wo gezeigt wird wien MZ Motor zerlegt wird. Kennt noch einer den Link?
-Dem Mann soll geholfen werden!
-- Hinzugefügt: 13.09.2009 20:45:58 --
I Found it!!!!!
Start "youtube.de" and search for "MZ Maintance" there you found what you are searching for. Of course you need some special tools.
Teemu hat geschrieben:Do you mean that I have to warm up the whole engine when taking it to two parts? I thought that the only place is some bearing that needs heat to come out.
Teemu hat geschrieben: So the gearwheels marked with an X in the photo above must be changed?
Lorchen hat geschrieben:Teemu hat geschrieben: So the gearwheels marked with an X in the photo above must be changed?
Nein. Das X markiert den Eingriff der Schaltgabeln.
Teemu hat geschrieben:The clutch puller that I have is similar to this one: clutch puller
And I made a big bang on the bolt as the clutch was very tight.
Norbert hat geschrieben:Disassembly + assembly only wenn the engine has a temperature of at least 100 degrees centigrade.
krocki hat geschrieben:Hi Teemu,
1100 Eu for a new engine in GDR original state? New engine sounds good. But probably you got the old seals and DKF bearings inside. And it has probably some original, tolerance-based "flow restrictions" inside (casing - to - cylinder channels and inside the cylinder channels).
The ignition can be changed without problems, only the support plate and the cam need to be changed.
You can even connect the blackbox to the contact, I guess the green wire is it. You have the original electronic ignition with the blackbox beside the battery?
It is difficult to tell, but I would build up the engine by myself. For 1100 Eu you get crankshaft (79-99), SKF bearings (60), seals, 3rd gear (50), screws, a one-row needle pin bearing, reinforced clutch springs, and still pretty much money left.
Work properly, with heating, cooling, not too much liquid seal. Leave the assembled block one week without oil, to allow the seal to harden to the core.
Riding with a self-rebuilt engine is a great feeling![]()
Carsten
Mitglieder in diesem Forum: Bratoletti, Google [Bot], Google Adsense [Bot] und 23 Gäste
