Aktuelle Zeit: 26. November 2025 00:47
 Betreff des Beitrags: Koso Instrument in ETZ 251
BeitragVerfasst: 14. April 2010 15:07
Hi, I would like install one KOSO instrument in my ETZ 251. I have the electronic ignition from powerdynamo.com. The tachometer work with one sensor in front wheel, this is not difficult to install. I can install too, one temperature sensor in the Cylinder head. My problem is set up the RPM in my ETZ 251. I dont understand much about this so I would like somebody help me understand where and how can I install the RPM
koso manual
electronic ignition
etz plan
Viva Cuba Libre!!!!
Fuhrpark: MZ ETZ 251/1990, MZ 1000 S/2005, ...
 Betreff des Beitrags: Re: Koso Instrument in ETZ 251
BeitragVerfasst: 14. April 2010 15:28
FE1 - TS250 Käufer
I would try to get the signal from yellow wire between sensor and ignition coil with rpm wire set A. But i´m not sure, please wait for other answers.
-- Hinzugefügt: Do 15. Apr 2010, 15:25 --
Bad news: push At first you should find out internal ratio of the Coso instrument, if you did it, you should contact Powerdynamo GmbH directly and describe your problem to them.
BeitragVerfasst: 28. April 2010 00:47
Thank for help. I hope some body try this install in the future, I will but not know. thank
Viva Cuba Libre!!!!
BeitragVerfasst: 28. April 2010 07:10
FE1 - TS250 Käufer
Installation finished successfully, or have you given up?
