Seite 1 von 1
[ 25 Beiträge ] |
| Autor |
Nachricht |
Lasse
Betreff des Beitrags: Discbrake on my TS250/0 Verfasst: 28. April 2010 08:41 |
Beiträge: 247 Wohnort: Dänemark Alter: 38
Hi! I am going to be putting on a discbrake on my TS250/0. I've bought a 16" frontwheel, and complete front-end from an ETZ. Now I thought it would be simple. But then I saw this. viewtopic.php?f=5&t=26216&start=50Now my german is not that strong, but it got me thinking, do I need to fabricate something? Or is it a straight swap? Regards, Lasse
| Nach oben |
Ralle
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 09:00 |
| Moderator |
Beiträge: 10919 Wohnort: Dresden Heimat: Oberlausitz Alter: 52
Lasse hat geschrieben: I've bought a 16" frontwheel, and complete front-end from an ETZ. 2 questions: What is "complete frontend", the telescopic fork including upper and lower clamping head? The 16" frontweel was mounted into this telescopic fork with disk before you bought?
| Nach oben |
guzzimk
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 10:05 |
Beiträge: 751 Wohnort: 63110 Alter: 61
Lasse hat geschrieben: Hi! I am going to be putting on a discbrake on my TS250/0. I've bought a 16" frontwheel, and complete front-end from an ETZ. Now I thought it would be simple. But then I saw this. viewtopic.php?f=5&t=26216&start=50Now my german is not that strong, but it got me thinking, do I need to fabricate something? Or is it a straight swap? Regards, Lasse Hi Lasse, please contact our member "trabimotorrad" (Achim), he does know how to do that ! Greetings Markus
| Nach oben |
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 10:28 |
Beiträge: 16859 Wohnort: Wüstenrot Alter: 65
Hi Lasse! When you will montain a disc-break in a TS250/0, you have to change the 32mm fork into a 35mm one. Then you can build in a 18" ETZ-front-wheel with disc brake. QWhen you hafe allready a 16"wheel with disc-brake, build in the wheel, the 3,5mm which MZ orded to put away from center, aren`t neccessarry. I´ve don myself with a 18" front whell and driven for a long time, without any Problems.
-- Hinzugefügt: Mi Apr 28, 2010 11:52 --
Edith says: A ETZ-fork has its own problem: There ist a "nose" on the TS250-frame, where the ID-Number ist printed and which is neccessary for closing the bike. The ETZ fork will not fit. You mus take a TS-35mm-fork!!
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:12 |
trabimotorrad hat geschrieben: Hi Lasse! When you will montain a disc-break in a TS250/0, you have to change the 32mm fork into a 35mm one. Then you can build in a 18" ETZ-front-wheel with disc brake. QWhen you hafe allready a 16"wheel with disc-brake, build in the wheel, the 3,5mm which MZ orded to put away from center, aren`t neccessarry. I´ve don myself with a 18" front whell and driven for a long time, without any Problems.
Edith says: A ETZ-fork has its own problem: There ist a "nose" on the TS250-frame, where the ID-Number ist printed and which is neccessary for closing the bike. The ETZ fork will not fit. You mus take a TS-35mm-fork!! The tripletrees won't fit? I don't need to be able to see the ID number. By complete front-end I mean tripletrees, wheel, axle, stanchions and lowerlegs. The wheel and fork hasn't been mounted together before.
| Nach oben |
Marco
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:16 |
Beiträge: 4074 Wohnort: bei Erfurt Alter: 46
To solve the problem with the nose ther are 3 different ways: 1st Go to your TÜV ingeneur (don't know how to say in another way) tell him the problem and ask him wheather it's possible to cut the nose and replace the ID on another place 2nd Take a dremel or another tool an start to cut the nose. But don't cut to much. Cut so much that the ID is still viewable. 3rd Mark the place where the lamp and the nose meet each other. Take the lamp off. Take a small hammer and hammer on the small place where the nose an the lamp meet each other.
| Nach oben |
Ralle
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:22 |
| Moderator |
...& 4th way is to get trippletrees (is it the same i named clamping head  ) from TS250/1, this could be te best way
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:23 |
Where can I find pictures of this "nose"? I can't imagine what it is. It doesn't matter if the ID is viewable, I have registered the bike and don't need to do so again, according to the rules of Denmark -- Hinzugefügt: 28. April 2010 14:25 --Ralle hat geschrieben: ...& 4th way is to get trippletrees (is it the same i named clamping head  ) from TS250/1, this could be te best way  I think triple tree is the american expression
| Nach oben |
MaxNice
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:30 |
Beiträge: 2483 Wohnort: Dresden Alter: 38
Ralle hat geschrieben: ...& 4th way is to get trippletrees (is it the same i named clamping head  ) from TS250/1, this could be te best way   did so this week
| Nach oben |
Ralle
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:33 |
| Moderator |
"The nose" is the pice of frame, where the lock is get in if you are locking the bike.
@MaxNice: Bleibt die Funktion des Lenkerschloßes eigentlich mit den TS/1 Gabelbrücken erhalten oder nicht?
Zuletzt geändert von Ralle am 28. April 2010 13:49, insgesamt 1-mal geändert.
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:34 |
Ralle hat geschrieben: "The nose" is the pice of frame, where the lock ist get in if you are locking the bike.
@MaxNice: Bleibt die Funktion des Lenkerschloßes eigentlich mit den TS/1 Gabelbrücken erhalten oder nicht? So if I don't have the lock it would be no problem at all with the ETZ clamps?
| Nach oben |
Ralle
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:47 |
| Moderator |
It only works with ETZ clamps if you cut of the nose from frame or use 3rd idea from mueboe
| Nach oben |
Marco
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 13:53 |
I used the 2nd method and the TÜV ingeneur was delighted with.
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 18:14 |
I will be using an ETZ headlight, will that change anything?
| Nach oben |
Marco
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 18:34 |
Oh yes, if you take the ETZ headlight id should fit. But i can't promise.
| Nach oben |
MaxNice
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 19:14 |
Ralle hat geschrieben: "The nose" is the pice of frame, where the lock is get in if you are locking the bike.
@MaxNice: Bleibt die Funktion des Lenkerschloßes eigentlich mit den TS/1 Gabelbrücken erhalten oder nicht? natürlich bleibt sie das, ich habe beide brückenpaare zur auswahl gehabt und aufgrund des lenkerschlosses hab ich die TS/1 brücken genommen. der prüfer war mit dem schloss auch zufrieden und wollte kein extra mitgeführtes.
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 19:48 |
MaxNice hat geschrieben: Ralle hat geschrieben: "The nose" is the pice of frame, where the lock is get in if you are locking the bike.
@MaxNice: Bleibt die Funktion des Lenkerschloßes eigentlich mit den TS/1 Gabelbrücken erhalten oder nicht? natürlich bleibt sie das, ich habe beide brückenpaare zur auswahl gehabt und aufgrund des lenkerschlosses hab ich die TS/1 brücken genommen. der prüfer war mit dem schloss auch zufrieden und wollte kein extra mitgeführtes. Also du verwenden nur die TS250/1 brücke weil das lenkerschloss fungieren muss?
| Nach oben |
MaxNice
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 20:10 |
yes, thats why I use the TS/1 triple trees. you'll have another vantage if you use it too, because of your headlight. my is a ETZ type with welded TS mountings, so it might be used on both triple tree types, but i decided for TS/1 triple trees. do it your way, it will be fine, if you have ETZ triple trees, use them and lock your bike with an external lock.
| Nach oben |
etzremo
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 20:14 |
| Ehemaliger |
Beiträge: 114 Wohnort: Gaildorf Alter: 58
Son Mist,ich kann kein englisch! Gruß etzremo
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 20:24 |
MaxNice hat geschrieben: yes, thats why I use the TS/1 triple trees. you'll have another vantage if you use it too, because of your headlight. my is a ETZ type with welded TS mountings, so it might be used on both triple tree types, but i decided for TS/1 triple trees. do it your way, it will be fine, if you have ETZ triple trees, use them and lock your bike with an external lock. An answer as clear as daylight, thank you!
| Nach oben |
MaxNice
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 28. April 2010 20:35 |
etzremo hat geschrieben: Son Mist,ich kann kein englisch! Gruß etzremo  ironie oder doch erklärungsbedarf? "ja das ist der grund, warum ich die TS/1 brücken benutze. du hast noch einen weiteren vorteil, wegen deiner lampe. meine ist eine von der ETZ wit angeschweißten TS befestigungen, man könnte man sie an beiden brückentypen TS als auch ETZ befestigen. dennoch entschied ich mich für die TS/1 brücken. bau es wie du denkst, es wird gut werden. wenn du ETZ brücken hast dann benutze sie und sichere dein motorrad mit einem lose mitgeführtem schloss (kettenschloss, etc)"
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 4. Mai 2010 19:29 |
Kann ich meine TS250/0 Lampenhaltern an die ETZ Brücke verwenden?
| Nach oben |
Marco
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 4. Mai 2010 19:32 |
Das sollte gehen. MZ schreibt bei Verwendung der ETZ Klemmköpfe aber das Kürzen der Lampendreiecke um jeweils 1 cm vor.
| Nach oben |
Lasse
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 4. Mai 2010 19:40 |
mueboe hat geschrieben: Das sollte gehen. MZ schreibt bei Verwendung der ETZ Klemmköpfe aber das Kürzen der Lampendreiecke um jeweils 1 cm vor. Will ein ETZ Scheinwerfer benutzen, will nur das Lampenhalter haben fürs Puig Scheibe haben.
| Nach oben |
MaxNice
Betreff des Beitrags: Re: Discbrake on my TS250/0 Verfasst: 4. Mai 2010 20:10 |
Lasse hat geschrieben: Kann ich meine TS250/0 Lampenhaltern an die ETZ Brücke verwenden? da wäre ich mir nicht so sicher, die standrohre sind ja dicker, wenn da noch 3mm platz sind gehts bestimmt.
| Nach oben |
Seite 1 von 1
[ 25 Beiträge ] |
