Aktuelle Zeit: 3. April 2026 17:20
Ein neues Thema erstellen Auf das Thema antworten  [ 1 Beitrag ]
 Betreff des Beitrags: Cutting out
BeitragVerfasst: 31. Mai 2010 16:32
Themen: 71
Hi guys
I've got the MZ engine overhauled and have now begun using it on the highway.
I run a tall gearing (Too tall tbh.) so it is hard for me to keep a good cruising speed in 5th. Today I tried downgearing to 4th and get it up through the revs; but when reaching the cruising speed of 5th it cut out on several occasions.
Shifting to 5th when this happens and everything returns to normal.
Before this I raised the needle one notch, because the old needle was so worn that it fell down one notch. I raised it because it could explain why it was having a hard time maintaining cruise speed if it was running too lean.
Now I am just thinking that it gets too much gas and empties the floatbowl chamber.
So here is what I am going to do:
Change the sparkplug - It's easy and needs to be done anyway.
Lowering the needle one notch - It ran this way before without me noticing anything. However, that was also with a lower gearing and a worn needle.
What do you think?
MZ ETZ engine - BVF carburettor - 20 tooth front sprocket (I weigh 68kg. and have 32L. Pneumant cases)
Fuhrpark: MZ ES250/2 1968
Yamaha XS650 1976
Mit Zitat antworten
Mitglieder in diesem Forum: Google [Bot] und 8 Gäste
Du darfst neue Themen in diesem Forum erstellen.
Du darfst Antworten zu Themen in diesem Forum erstellen.
