I put a short description of my motorcycle:
I own a MZ/ETZ 250 from 1988. After I’ve bought it in 2008 I’ve start to modify, special for more reliability… the electronic part was in the first plan … rewiring, changing the turn lights and park light/stop light into led’s(diy stuff), ignition unit ( I changed the old ignition unit (ignition coil, mechanical contact breaker, condenser) for a Opel Astra F(16NZ) ignition coil, Hall sensor(TLE4905) and a mosfet final drive) and the original carburetor to a Mikuni. All those modification are not for show of and I’ve keep the original outside esthetic, for example the LED’s lights cannot be noticed just only when are ON, the covers of turn lights and park/stop light are all original I’ve build from scratch all those modules (all those I will present in other topic).
And back to my main problem:
When I bought the motorcycle was in a good condition, esthetical and mechanical but after a few months later it begin showing the hidden problem, start with the crankshaft bearing, at high engine revolution (when it reach the maximum torque) some noise come out from engine(the feeling was similar with rev limit).I’ve think something is wrong with the piston head, so I take down the cylinder but all was normal, surprised clean(I use full synthetic oil). When I’ve changed the ignition signal pick-up on the crankshaft I’ve notice an ‘up and down’ movement of the crankshaft, this movement was produced by the ‘tired’ crankshaft bearings. When I’ve open the engines I’ve noticed the reason for the main bearings was ‘out of service’, the crankshaft and the clutch had been modified and wasn’t centered properly and generate an irregular clutch rotation which damage the bearings and produced that noise.
Now I need to buy a new one but don’t know which I should choose from those (I need to change both crankshaft and the clutch):
1.
http://s40205778.shoplite.de/sess/utn;j ... shopscript
Kurbelwelle ETZ250/251 -NEU => 75,00 € (Bestellnummer: 00302)
Kupplungskörper TS/ETZ250 => 31,50 € (Bestellnummer: 40587A)
2.
http://www.ost2rad.de/MZ-Ersatzteile/Zy ... Z-250.html
Kurbelwelle ETZ 250 / 251 / 301 => 117,00 EUR (Art.Nr.: 590)
Kupplungskörper MZ 250 => 24,70 EUR (Art.Nr.: 1031)
3.
http://www.oldtimerteile-haase.de/produ ... 51_301.php
Kurbelwelle neu - ohne Altabgabe => 105,00 EUR (Bestell-Nr. 12307)
Kupplungskörper ORIGINALERSATZTEIL => (MZ-Nummer05-44.153)33,50Euro (Bestell-Nr.12410-3)
Had someone ordered from those online shops? Which of them are better, because I see the price are quite different…. or perhaps you know a better shop?
ps. you can replay in german language, i use google translator and it is quite good.
Thanks in advanced!
