MZ 125 RT Disassembly HELP!
Beitragvon turbinee » 1. März 2011 13:13
Hi guys,
Sorry to bother you from Bulgaria, and not in German, but I have a problem and I need your help with it.
I have an 125 rt that I've restored almost completely, but I have a problem disassembling the front forks. I can find how to remove the (Hohlschraube in German) I think.
Can someone walk me trough the disassembly and assembly procedure for the forks please.
Also I tried to bolt back the shocks to the triple tree with the bolts on the top of the shocks, but the bolts can't grab onto something, why is that? Is there a part inside that moves freely or what?
Please help me out,
If someone also have some pictures of the shock and the components and the way they go together please include that as well.
Thank you,
George
Fuhrpark: mz 125 rt
turbinee
Re: MZ 125 RT Disassembly HELP!
Beitragvon Ralle » 1. März 2011 13:27
Welcome here!
You are sure that the fork is assembled with these "Hohlschrauben"? Later versions there have a circlip :idea: What kind of MZ RT is yours, /1 /2 or /3?
If the bolds on top should grab, you have to compress the fork.
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 1. März 2011 13:31
Mine is 125/4
It has the round circlip below the hohlschrauben and I removed it trough the small round hole on the side of the shock's body, and that's it.
Now I tried to dissasemble it but to no avail, it will not move (the hohlschrauben that is).
Also I tried to compress the shock and screw the bolt in but nothing happens, the bolt just spins and will not grab onto anything. I wonder if maybe I used the wrong bolt diameter ( I tried to fit an 8mm bolt).
Fuhrpark: mz 125 rt
turbinee
Beitragvon Ralle » 1. März 2011 13:46
I have seen the pictures in your galery now, this type is very rare 8)
turbinee hat geschrieben:It has the round circlip below the hohlschrauben and I removed it trough the small round hole on the side of the shock's body, and that's it.
Thats the rigt way, on your fork there is no "Hohlschraube". Next step is to remove the grease nipple. With a little luck you can disasambele the fork now, in worst case you need a lot of power and it´s possible you hav to use heat.
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 1. März 2011 13:57
So I should remove the grease nipple first and then just pull to get it out?
Ok, and for the assembly I just need to compress the shock and get the bolt in. How about the size of the bolt, is 8mm correct.
I ask you because I've disassembled the bike 5 years ago and cant remember which bolt is for the forks.
Fuhrpark: mz 125 rt
turbinee
Beitragvon Ralle » 1. März 2011 14:04
turbinee hat geschrieben:So I should remove the grease nipple first and then just pull to get it out?
Yes
turbinee hat geschrieben:Ok, and for the assembly I just need to compress the shock and get the bolt in. How about the size of the bolt, is 8mm correct.
Not correct, you have to use M10x65 :!:
Here you can find a spare part list fom RT125/2. The fork you find on table 11, it´s identical in most parts to your fork, only the assemble by circlip is different.
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 1. März 2011 14:09
Thank you,
You've been most helpful!
I'll post some more pictures with the progress of the bike.
Thanks,
George
Fuhrpark: mz 125 rt
turbinee
Beitragvon Ralle » 1. März 2011 14:21
Yes, we want to see more pictures of these rare bike :flehan: , you have done some pictures bevore start restortion? When the motorcycle was manufactured? The officially number of manufactured MZ125/4 is 4904 pices, non of these officially exportet to Bulgaria :shock:
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 1. März 2011 14:40
Mz 125/4 is what it says on the metal plate behind the triple tree.
I'll post some, but the pictures are not pretty ;)
I'll also look at the plate and verify that is 125/4 for you.
If you're interested I'll post the serial numbers as well.
Fuhrpark: mz 125 rt
turbinee
Beitragvon turbinee » 10. März 2011 09:55
Just added the serial No label, on it it says 125-4.
Fuhrpark: mz 125 rt
turbinee
Beitragvon motorradfahrerwill » 10. März 2011 18:09
Thank you very very much for this information. :ja:
Btw : Welcome in the best MZ-Forum of the galaxy. ;D
MfG Kurt
Fuhrpark: .-.
motorradfahrerwill
Beitragvon Ralle » 11. März 2011 07:39
A 4-digit number with an E at the end, very interesting...
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 14. März 2011 19:43
Thanks for the welcome :)
The serial# is actually the normal length, I just covered the last digits and left only the first four visible.
I,ve assembled the front suspension and will post the pictures soon.
Fuhrpark: mz 125 rt
turbinee
Beitragvon Ralle » 15. März 2011 07:50
turbinee hat geschrieben: I just covered the last digits and left only the first four visible.
Perfekt counterfeit ;D
turbinee hat geschrieben:I,ve assembled the front suspension and will post the pictures soon.
Congratulations, we are pleased that we could help. Incidentally, it is possible to insert images directly into your posts :ja:
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 17. März 2011 18:15
You know, I've never could understand how exactly it is done (to insert images that is) in the post.
By the way I've just completed majority of the work on the custom muffler I'm building, will make some photos and will post them tomorrow.
Fuhrpark: mz 125 rt
turbinee
Beitragvon Ralle » 18. März 2011 08:13
A customized muffler, I'm curious :gespannt:
To upload photos or other files:
During you´re writing a new post, there are two tabs below the text box.
Click at "Dateianhang hochladen" 1 (upload file), next step is "Durchsuchen..." 2 (search), now you can search and select the file you want to upload on your computer. Then click at "Datei hinzufügen" 3 (attach file) and wait a few seconds.
Now you can see the name of uploadet file below the text box.
box
Set cursor on the position into text box, where the file should be inserted into the text, next click at "Im Beitrag anzeigen" 4 (show into the post) and you can see
Code: Alles auswählen
 [attachment]file name[/attachment]
into text box. To become a preview of your post, you can use the "Vorschau" button, left next to "Absenden", but do not forget to click "Absenden" after a preview, to upload your complete post into the forum :wink:
P.S. @all: Falls jemand gravierende Fehler im Text findet, können die gerne korrigiert werden, ich bin kein Profi :oops:
Ralle
FE1 - TS250 Käufer
Beitragvon turbinee » 20. März 2011 10:04
Here is a pic from last week...
Today I have a friend photographer come and do some more shots of the bike, hopefully I'll be able to show you some better pictures tomorrow.
Fuhrpark: mz 125 rt
turbinee
Beitragvon turbinee » 12. April 2011 08:49
Beauty shot :D
Fuhrpark: mz 125 rt
turbinee
Beitragvon Insulaner4 » 12. April 2011 10:20
... und schon in der Bucht gefunden...
http://cgi.ebay.de/MZ-RT-125-4-rare-pro ... 2c5c01ecf5
Blackberry PIN: 7BCC0FCB
Insulaner4
Beitragvon turbinee » 12. April 2011 15:16
Thank you for pointing that out, in fact it is listed in Ebay as of yesterday.
As I pointed in the auction I need to get this project sold so that I can finance the next one, and sure you are more than welcome to bid :D on it.
I'd be glad if the bike goes to a member of the MZ comunity.
George
Fuhrpark: mz 125 rt
turbinee
Mitglieder in diesem Forum: Baidu [Spider], Majestic-12 [Bot] und 14 Gäste
