Just one Bulb in Backlight!!! Hilfe
Beitragvon pepin1234 » 22. November 2011 00:53
hi can anyone help with the installation of the backlight. I have a MZ-ETZ 251. The Backlight I have currently have 2 bulbs. This light is broken and I've bought a new one. The surprise is that when I open the new Backlight Just have 1 bulb.
My question is if I connect the positive of 21 w (brake) and 5 W (Backlight) together, may have a breakdown?? Work well the backlight and brake light in this way???
Viva Cuba Libre!!!!
Fuhrpark: MZ ETZ 251/1990, MZ 1000 S/2005, ...
pepin1234
Re: Just one Bulb in Backlight!!! Hilfe
Beitragvon Ralle » 22. November 2011 01:03
At the picture in your gallerie is see the oblong MZ- backlight, this back light should have also only one bulb. Is there currently mounted another one?
Ralle
FE1 - TS250 Käufer
Beitragvon pepin1234 » 22. November 2011 01:20
Ralle hat geschrieben:At the picture in your gallerie is see the oblong MZ- back light, this backlight should have also only one bulb. Is there currently mounted another one?
now I have 2 light bulbs. The support is completely original. How I can resolve this??? I can install the new backlight with a single light bulb???
Viva Cuba Libre!!!!
pepin1234
Beitragvon Ralle » 22. November 2011 03:16
If the bulb has two filaments inside it is possible to install the new back light.
I am surprised that your current back light has two bulbs, I have never seen this before :shock: could you make a picture from the inside please?
At first you have to check if the two bulbs in your current back light are switched by ground or positve pole. In the latter case you must only connect the positive wires from brake light and rear light to the corresponding connetions from new back light. If ground is switched you have to change some more connections from cable tree. Here you can see an wiring diagram, made from member Harry, it is 100% compatible to the original one (with one bulb with two filaments). If you need some more assistance you´re welcome.
Frage an alle, kennt jemand das eckige MZ- Rücklicht mit 2 getrennten Glühlampen, wenn ja wann und wo wurde es verbaut???
Ralle
FE1 - TS250 Käufer
Beitragvon net-harry » 22. November 2011 08:15
You can easy change the wiring between one and two bulbs in your backlight.
Look at the pictures...
Harald
net-harry
Themen: 67
Beitragvon pepin1234 » 22. November 2011 14:17
ok so I think is not hard to make it. So I will keep the same configuration just set the 5w and 21w wires to the corresponding setting of the bulb, braun to ground and a new bulb of 21/5W 12v. I will upload the picture of my old backlight you can see what I say.
Thnak
Viva Cuba Libre!!!!
pepin1234
Beitragvon mutschy » 22. November 2011 21:07
Ralle hat geschrieben:Frage an alle, kennt jemand das eckige MZ- Rücklicht mit 2 getrennten Glühlampen, wenn ja wann und wo wurde es verbaut???
Ja, hier, ich :D
Diese Rücklichter werden auch als Ersatz für die 12V-Modelle von Simson (wie zB auch bei BSL100 u BSL122 waren Simson- u MZ-Rücklichter baugleich) von MZA & Co. vertrieben u haben auch ne gemeinsame Masse (wie die originalen), aber 2 Birnenfassungen, einmal oben ne BA15S fürs Bremslicht u einmal unten ne BA9S fürs Rücklicht. Wichtig: Die üblichen BA9S (egal, ob 6 oder 12V) haben mW nur 4W, was zB bei der Simme zu weiteren Problemen führen kann. Bei Interesse schreib ich gerne mehr dazu ;)
Mutschy
MZ TS 150, BJ 1981, "Valerie"
(früher)
mutschy
Themen: 172
Beitragvon es-etz-walze » 22. November 2011 21:29
hey,ich kann dir helfen. ich wohne in lampertheim. ich kann es mir gerne anschauen.
-- Hinzugefügt: 22. November 2011 20:34 --
mutschy hat geschrieben:
Ja, hier, ich :D
Mutschy
moin,die eckigen rücklichter waren keineswegs bei simson u mz gleich. die eckigen simson rücklichter sind nicht so "tief" und haben an der unterseite keine kennzeichenbeleuchtung. lg
Fuhrpark: 5125ccm (MZ)
es-etz-walze
Beitragvon mutschy » 22. November 2011 21:53
Ich kann mich nich entsinnen, dass jemals Unterschiede gemacht wurden, abgesehen von der Streuscheibe für die Kennzeichenbeleuchtung, aber ich lerne gerne dazu u will mich nich streiten.
Wobei die fehlende (weil nie vorgesehene) Kennzeichenbeleuchtung schon so manchem Simsonauten Probleme bereitet hat, hat er den §27FZV(4)Satz2 nich sofort griffbereit gehabt :roll:
Mutschy
(früher)
mutschy
Themen: 172
Beitragvon es-etz-walze » 22. November 2011 22:06
ohhhhhh noooooooo...kein streit :)
ich hab so ein rücklicht an meiner etz dran---stammt von einem s53. es ist auch definitiv kein nachbau,das licht ist schon seit 15j verbaut :wink: lg
-- Hinzugefügt: 22. November 2011 21:22 --
es-etz-walze
Beitragvon Ralle » 22. November 2011 22:26
Ok, die Rücklichter sind dann aber in jedem Fall auch Plus- geschaltet, Pepin braucht also nur die Masse zusammen nehmen, oder eins weglassen und die beiden Plus Leitungen an den jeweils entsprechenden Anschluß der Fassung für die 2 Faden- Glühlampe klemmen?
Ralle
FE1 - TS250 Käufer
Beitragvon es-etz-walze » 22. November 2011 22:38
wenn es die blaue 251er ist,dann kommen doch eh nur 3drähte hinten an...wie gesagt,ich wohn nur 10min von ihm entfernt...
es-etz-walze
Beitragvon Ralle » 22. November 2011 22:46
Weiß er das? Wenn nicht dann spätestens ab jetzt :wink:
Ralle
FE1 - TS250 Käufer
Beitragvon es-etz-walze » 22. November 2011 22:58
komisch... :roll: hab doch vorhin schon geschrieben,das ich in lampertheim wohne...
es-etz-walze
Beitragvon Ralle » 22. November 2011 23:08
..ging über dem großen Zitat unter :lol:
Ralle
FE1 - TS250 Käufer
Beitragvon pepin1234 » 24. November 2011 17:54
Here is what I talking about!!! my old one:
Viva Cuba Libre!!!!
pepin1234
Beitragvon es-etz-walze » 24. November 2011 18:53
wenn das "neue" rücklicht nur eine fassung hat,benötigst du eine 2-faden-glühlampe. 21w/5w dann die drähte dran stecken und fertig :hallo:
wie gesagt,ich biete dir meine hilfe an,lg
es-etz-walze
Mitglieder in diesem Forum: Dieter, Matapyr und 10 Gäste
