Aktuelle Zeit: 10. Februar 2026 09:18
 Betreff des Beitrags: Silverstar Hauptstande (again)
BeitragVerfasst: 11. Februar 2012 15:33
After 6 months of looking I finally found a centrestand, from Germany, that was supposed to fit my silverstar.
However,it doesn't fit !! :(
I found a picture on the internet of a Silverstar, with a stand, where it appears to be fitted through holes in the frame that my silverstar doesnt have.
There are no holes on my frame:
in fact there is nowhere for the stand to fit . as the brake is in the way
_________
John Nash
Herefordshire UK.
Fuhrpark: 2004 Royal Enfield Army
1996 MZ Silverstar
1980 XS650
1968 CJ750
1963 Ural M62 Outfit
1954 Ariel VH500 outfit
1951 Ariel KH500
1947 Ariel VH500
1944 Ariel WNG (military)
1940 Enfield WDCO (military)
Zuletzt geändert von madoc am 11. Februar 2012 16:22, insgesamt 1-mal geändert.
 Betreff des Beitrags: Re: Silverstar Hauptstande (again)
BeitragVerfasst: 11. Februar 2012 16:00
Der Bruder
viewtopic.php?f=98&t=19651&hilit=silverstar+hauptst%C3%A4nder
OT-Tretstartpartisane
Der Rotax Freilauf
Speichenlängen MZ
Fuhrpark: TS 250 im Aufbau
MZ 500 R wieder im Aufbau
BeitragVerfasst: 11. Februar 2012 16:36
I read it; it is no help.
It is a good debate but no conclusions.
Does the silverstar need a separate "fitting kit" or not ? I do not know.
_________
John Nash
Herefordshire UK.
1996 MZ Silverstar
1980 XS650
1968 CJ750
1951 Ariel KH500
1947 Ariel VH500
BeitragVerfasst: 11. Februar 2012 16:39
Themen: 104
ETZ_muffel
what the "Bruder" mean is,you'll need another downstand beam,there is one for centerstand and one without. Take a look in the linked thread, you'll find some pics.
Uwe
 Profil Persönliches Album
BeitragVerfasst: 11. Februar 2012 16:58
Ah, I see, I wish I had seen this before I bought a stand.
I think finding another "beam" (for a centrestand) will be very, very, very hard ...
_________
John Nash
Herefordshire UK.
1996 MZ Silverstar
1980 XS650
1968 CJ750
1951 Ariel KH500
1947 Ariel VH500
BeitragVerfasst: 11. Februar 2012 17:58
Themen: 104
ETZ_muffel
In German this part called "Unterzug", one option, give a call to "Motorradente" he's a dealer, contact you can found here.
Uwe
-- Hinzugefügt: 11/2/2012, 17:59 --
hope it helps:
Ente
Zuletzt geändert von muffel am 11. Februar 2012 21:43, insgesamt 1-mal geändert.
BeitragVerfasst: 11. Februar 2012 18:09
Der Bruder
Just do not give up
It is currently Sun cold, when it is warmer, I can acces my photo taking pictures so that you can rebuild him
The conversion is not exciting and should be feasible
There are only new recordings are welded to the main stand
Der Rotax Freilauf
Speichenlängen MZ
BeitragVerfasst: 11. Februar 2012 20:59
Here's another shot of the Silver Star subframe that has the welded bungs for the center stand. This is looking at it from the rear. I just sent my last center stand to a bloke in the UK; obviously he had the center stand provisions on his Silvy since it bolted right on. I do have a couple of these subframes with center stand provisions, but shipping it would be a killer from the US.
-Donny
Fuhrpark: 1-3/4 1995 MZ Silver Star
BeitragVerfasst: 12. Februar 2012 00:01
Der Bruder hat geschrieben:
Just do not give up
I'd appreciate this.
thank you .
Donny hat geschrieben:
Hmmmm something to think about
Thanks Donny
I will investigate the other sidestand
I met a random bloke today; 2-stroke MZ owner.
He told me that the rear wheel axle, sidestand, from an etz will fit
He pointed out that my silverstar hub even had the undrilled mouldings for the switch mountings.
That may be what the earlier chap what talking about.
_________
John Nash
Herefordshire UK.
1996 MZ Silverstar
1980 XS650
1968 CJ750
1951 Ariel KH500
1947 Ariel VH500
BeitragVerfasst: 19. Februar 2012 10:59
I just bought and fitted one.
I guess this already known on this forum, but this is a replacement for the rear axle spacer.
Straight fit to a silver-star and much more stable than the original side stand
The two spring version "flies up" when the weight is taken off.
Part number ? Is it 30 25 077 ? Not sure.
_________
John Nash
Herefordshire UK.
1996 MZ Silverstar
1980 XS650
1968 CJ750
1951 Ariel KH500
1947 Ariel VH500
BeitragVerfasst: 10. April 2012 22:44
I like this hauptstande! Much better than the original. :mrgreen:
-Donny
