 Betreff des Beitrags: Silverstar Hauptstande (again)
BeitragVerfasst: 11. Februar 2012 15:33
After 6 months of looking I finally found a centrestand, from Germany, that was supposed to fit my silverstar.
However,it doesn't fit !! :(
I found a picture on the internet of a Silverstar, with a stand, where it appears to be fitted through holes in the frame that my silverstar doesnt have.
There are no holes on my frame:
in fact there is nowhere for the stand to fit . as the brake is in the way
Zuletzt geändert von madoc am 11. Februar 2012 16:22, insgesamt 1-mal geändert.
 Betreff des Beitrags: Re: Silverstar Hauptstande (again)
BeitragVerfasst: 11. Februar 2012 16:00
viewtopic.php?f=98&t=19651&hilit=silverstar+hauptst%C3%A4nder
BeitragVerfasst: 11. Februar 2012 16:36
I read it; it is no help.
It is a good debate but no conclusions.
Does the silverstar need a separate "fitting kit" or not ? I do not know.
BeitragVerfasst: 11. Februar 2012 16:39
what the "Bruder" mean is,you'll need another downstand beam,there is one for centerstand and one without. Take a look in the linked thread, you'll find some pics.
Uwe
BeitragVerfasst: 11. Februar 2012 16:58
Ah, I see, I wish I had seen this before I bought a stand.
I think finding another "beam" (for a centrestand) will be very, very, very hard ...
BeitragVerfasst: 11. Februar 2012 17:58
In German this part called "Unterzug", one option, give a call to "Motorradente" he's a dealer, contact you can found here.
Uwe
-- Hinzugefügt: 11/2/2012, 17:59 --
hope it helps:
Ente
Zuletzt geändert von muffel am 11. Februar 2012 21:43, insgesamt 1-mal geändert.
BeitragVerfasst: 11. Februar 2012 18:09
Just do not give up
It is currently Sun cold, when it is warmer, I can acces my photo taking pictures so that you can rebuild him
The conversion is not exciting and should be feasible
There are only new recordings are welded to the main stand
BeitragVerfasst: 11. Februar 2012 20:59
Here's another shot of the Silver Star subframe that has the welded bungs for the center stand. This is looking at it from the rear. I just sent my last center stand to a bloke in the UK; obviously he had the center stand provisions on his Silvy since it bolted right on. I do have a couple of these subframes with center stand provisions, but shipping it would be a killer from the US.
BeitragVerfasst: 12. Februar 2012 00:01
Der Bruder hat geschrieben:
Just do not give up
I'd appreciate this.
thank you .
Donny hat geschrieben:
Hmmmm something to think about
Thanks Donny
I will investigate the other sidestand
I met a random bloke today; 2-stroke MZ owner.
He told me that the rear wheel axle, sidestand, from an etz will fit
He pointed out that my silverstar hub even had the undrilled mouldings for the switch mountings.
That may be what the earlier chap what talking about.
BeitragVerfasst: 19. Februar 2012 10:59
I just bought and fitted one.
I guess this already known on this forum, but this is a replacement for the rear axle spacer.
Straight fit to a silver-star and much more stable than the original side stand
The two spring version "flies up" when the weight is taken off.
Part number ? Is it 30 25 077 ? Not sure.
BeitragVerfasst: 10. April 2012 22:44
I like this hauptstande! Much better than the original. :mrgreen:
