[IWL] battery goes flat, doesn't charge
Beitragvon amkrisis » 8. März 2012 17:03
Hello
I have an IWL Berlin engine with electronic regler. The battery charge light doens't go out when reving the engine, and when the engine is running and I measure the battery I only get 0.5v!
When it's shut down I measure 6v which is fine.
The bike runs ok but drains the battery very quickly.
Could it be that I switched the DF and D+ on the lima and regler so it's using power instead of giving it back?
Is it safe to switch them to test?
Cheers from Belgium.
Benny
Fuhrpark: IWL Wiesel SR56 with Berlin SR58 engine
amkrisis
Re: [IWL] battery goes flat, doesn't charge
Beitragvon ea2873 » 8. März 2012 22:42
do you have the original generator oder the MZ-B/Vape? which kind of regulator do you have? can you make a photo? did you change the regualtor, has it ever worked with the electronic regulator?
Beitragvon Ralle » 9. März 2012 12:32
This would be my question also, blease upload a picture of the regulator. But if it`s a MZ-BPowerdynamo/Vape regulator R81 please check the manufactoring date, if it`s 35/10 maybe there ist a incorrect marking...
Ralle
FE1 - TS250 Käufer
