mediocre charge rate...Resolved
For non German-speakers. We will try to discuss in your language here, preferably in English. Guest posts welcome.
Beitragvon MichaelTorre » 6. April 2015 05:27
Hello again,
I am hoping to be able to adjust the voltage regulator on 1974 ts250 - 0.
Charges at a rate of 6. 1 volt at 2500 rpm, was wishing to raise that to 6.3 volts.
My genuine MZ manual doesn't detail about a judgment. It lists the gaps but it doesn't tell which gaps correspond to the measurements given.
no word for manual adjustment, just a phrase take to a specialist. so
Here I am, I have gone to the specialists.
Thank you.
Michael
Zuletzt geändert von MichaelTorre am 23. Mai 2015 06:07, insgesamt 1-mal geändert.
Fuhrpark: MZTS250/0,
Yamaha Standard 1100
MichaelTorre
Re: mediocre charge rate
Beitragvon luckyluke2 » 6. April 2015 06:29
Hello Michael , you can download the Electricmanual from Lothar , he is one from our Electrikspecialists . It is an PDF ; may be you can translate this . Look to page 22-24 . ;D
MZ Electric
Zuletzt geändert von luckyluke2 am 6. April 2015 09:23, insgesamt 1-mal geändert.
Beitragvon lothar » 6. April 2015 09:02
Maybe it´s easier to look at this figure:
Move the aluminium tongue (blue point) to change the voltage. But be careful this aluminium tongue breaks easily.
In your case it is more recommended to insert a narrow paper sheet like red arrow shows. Doing so the voltage will increase.
Watch the effect by your DVM and insert as many sheets until the voltage will have been climbed up on the desired value.
Be patient the voltage jumps often too high or too low.
But note: There are a few other reasons for loo low voltage at battery terms. Check all cable connectors between regulator,
ignition switch in the lamp, fuses and battery. Often the main switch or the fuses are responsible for a non-acceptable voltage drop.
Also note that the nominal voltage at battery terminals is 6,8V ... 7,0V at about 3000min-1 and full light (6,3V is too less).
Regards
Lothar
lothar
Beitragvon ea2873 » 6. April 2015 10:07
unless you are not keen of using the original regulator use the Vape electronic regulator.
as Lothar said, bevore changing the regulator, start cleaning/check the cable shoes and the fuse panel, normally you will be loosing some 1/10V there.
Beitragvon MichaelTorre » 6. April 2015 18:23
checking the connections is relatively easy.
I use a voltmeter digital and look for a voltage drop when straddling a connection.
Quick and easy.
.....so
the accumulated thickness of the paper is to indicate the amount I need to bend the aluminum tab?
it appears to be delicate. That's okay I have a light touch.
*****************************edit 5/9/15; charging at a nice fat 7.1 volts at 2500 rpm now.
Thank you. ****************************************************************
Michael
Zuletzt geändert von MichaelTorre am 23. Mai 2015 06:09, insgesamt 2-mal geändert.
MichaelTorre
Beitragvon lothar » 6. April 2015 20:14
MichaelTorre hat geschrieben:the accumulated thickness of the paper is to indicate the amount I need to bend the aluminum tab?
Correct. But you can also leave the paper there if the voltage is OK. It saves the aluminium tongue for unnessecary bending.
lothar
Beitragvon MichaelTorre » 6. April 2015 20:50
That's great!
Thank you for a "non-invasive" fix.
Regards
Michael
Zuletzt geändert von MichaelTorre am 23. Mai 2015 06:12, insgesamt 3-mal geändert.
MichaelTorre
Beitragvon smokiebrandy » 6. April 2015 22:00
If you come to Germany... you have to dial .....
BSA 650 Goldstar Bj.2026
smokiebrandy
Zurück zu Questions and Answers
