Pannier Frames/Gepäckträger/Seitengepäckträge for Mz Country
Beitragvon brennain1 » 20. März 2013 09:20
Hello, can anyone supply me with pictures as to how pannier frames would fix to an Mz Country. Is there anywhere to buy these pannier frames? Also did the Mz Country come with Bilstein rear shocks as standard? Thanks.
Fuhrpark: MZ Typ/660 Scourpion, MZ Typ/500 Country,
brennain1
Re: Pannier Frames for Mz Country
Beitragvon ETZChris » 20. März 2013 09:30
Beitragvon brennain1 » 20. März 2013 09:44
Hi and thanks for the reply, is there anyone who could translate this pdf http://neu.hepco-becker.de/Montageanlei ... 3.0001.pdf
brennain1
Beitragvon ETZChris » 20. März 2013 09:49
what information do you need?
the complete text? it's only the assambly instruction.
Beitragvon brennain1 » 20. März 2013 09:57
I was hoping it would give me the mounting points for the frame. I already have Hepco frames and panniers that i was hoping to modify and make fit.
brennain1
Beitragvon ETZChris » 20. März 2013 10:00
ah okay.
maybe some of the country owner can make pictures.
in a free minute I'll translate some facts of the mounting descriptions :ja:
-- Hinzugefügt: 20/3/2013, 10:28 --
I searched for some pictures but didn't find some good ones.
but while looking at them viewtopic.php?p=863309#p863309 I saw the mounting points, I think.
remount the seat and the cover below it.
then you see the frame and different holes. one is for the shocks. the others are for the panniers.
on the rear end of the frame it's similar. the free holes are for the pannier, the others should be used by the back handle.
the other mounting points are on the passangers footrests and on the backside of the fender.
the picture in the pdf shows it a little bit.
Beitragvon g-spann » 20. März 2013 10:32
brennain1 hat geschrieben: Also did the Mz Country come with Bilstein rear shocks as standard? Thanks.
Yes, they did...
Beitragvon brennain1 » 20. März 2013 11:46
Hi Chris, yes I think I can see the mounting points in the pictures. In the 1st picture there are 2 tubes looking down just to the rear of the crossmember, i'm assuming that these could be the rear mounting points?
Hi Gerd, did the Country also come with a tool kit and where was it stored, also what did it contain? Mine as far as I can see doesn't have one.
brennain1
Re: Pannier Frames/Gepäckträger/Seitengepäckträge for Mz Cou
Beitragvon trabimotorrad » 20. März 2013 12:05
Thema verschoben und ergänzt
Themen: 143
Beitragvon ETZChris » 20. März 2013 12:16
thanks, achim :)
Beitragvon Nordtax » 20. März 2013 16:31
brennain1 hat geschrieben: Is there anywhere to buy these pannier frames?
I have used ones to sell, need some paint.
Nordtax
Beitragvon brennain1 » 21. März 2013 21:02
Nordtax hat geschrieben:
Hello Nordtax, have PM'd you.
brennain1
Zurück zu Fahrwerk - Rotax (500ccm)
