Mz es 250/2 Garage
For non German-speakers. We will try to discuss in your language here, preferably in English. Guest posts welcome.
Mz es 250/2 Garage
Beitragvon mario1300 » 9. November 2013 09:07
Hi guys!
I come from Croatia,and I have some questions about different cylinders that look almoust the same(ES/ETS/TS),are they compatible together with ES 250/2 3=10 head or 1=10 head?
This is the 05-42-062 ES 250/2 cylinder s16 from 1971.g:
The 05-42-062 made in 1976,Is this the TS cylinder?Can it be fitted to ES 250/2 engine and ES 250/2 cylinderhead?
The red arrow marks the˝ring˝ that the 05-42-062 ES 250/2 cylinder s16 from 1971. doesn´t have...this cylinder was bought at ebay.de titled as an ES TS ETS 250 cylinder...
This 76 cylinder fits the TS 250 cylinderhead really nice,the diamater of the ˝ring˝on the cylinder and the circular pit on the 250 ts cylinder head are the same:
If this ˝ring˝ was precisely removed ,could then this 76 cylinder be compatible with ES 250/2 3=10 or 1=10 cylinder Heads??
Few Questions about cylinderheads...
The area marked with red is lower than the area marked with blue colors...why?For cooling maybe?
On the cylinder head of 250 TS the surface is all straight...
Thanks for answer
Zuletzt geändert von mario1300 am 26. Dezember 2015 16:06, insgesamt 1-mal geändert.
Fuhrpark: MZ ES 250/2
mario1300
Re: Mz es 250/2 Cylinder/ cylinderhead help
Beitragvon Überströmer » 9. November 2013 10:16
Dear Goldilox,
yes you´re right the cylinders and also the cylinder heads of TS and ES for 250ccm are quit different in regard to there common sealing area. The parts of ETS are the same used in the ES.
The reason for is that at TS a sealing made from metal is used which is fixed on the right position with this ring you´ve measured with your caliper.
The sealing at ES and ETS is only assured by direct contact of this two units. To reach this and to avoid decreasing pressure the coloured areas at the ES cylinder head are required so that the contact only will be done at the inner blue circle. At TS this is given by the used sealing so the cylinder head can be straight.
For information also the cylinder with the cylinder head of the TS can be used on the ES engine.
Good luck and best regards.
Fuhrpark: RT 125/3
ES 150/1
ES 125/G-5 (im Aufbau)
ES 250
ES 250/2 mit PSW
TS 150
TS 125
ETZ 250
ETS 250
IFA BK 350
ETZ 150 (2x)
Baghira SM
Überströmer
Beitragvon mario1300 » 9. November 2013 20:23
Thanks for answering...so it means that the piston rods on ES,ETS and TS are the same??
If piston rods are the same then this 76 cylinder with the ring,needs to be shorter(comparing it with 71 ES 250/2 cylinder without the ring) at some section for the dimension of the ring(about 1.5 mm)... :?
Some of my questions are still not answered :cry: ... :twisted:
mario1300
Beitragvon ertz » 9. November 2013 21:05
here some Informations about Cylinder -Heads for ES 250/2 and 175.
download/file.php?id=23699&kb=1
Here the different Cylinders from TS, ES.
viewtopic.php?f=4&t=60683
The diffrence from 17 Horsepower to 19 Horsepower - Cylinders:
on Page 2 : viewtopic.php?f=4&t=29703&hilit=Zylinder+19ps+17ps
Bye
ertz.
ertz
Beitragvon Christof » 9. November 2013 22:42
The Cylinder of the ES 250/2 with 19HP has to be fitted with a cylinderhead wich is marked with "MM250/2 e=10:1" underneath the lowest ridge. The Cylinder with the centerring has to be fitted with the cylinderhead which is marked with "MM 250/3 e=10:1". Both cylindera uses an equal rod and piston.
Beitragvon mario1300 » 10. November 2013 01:03
Thanks for answers guys.
dont have the cylinder head beside me now,but...this cylinderhead should fit the 71.cylinder 05-42-062 without the center ring(?):
mario1300
Beitragvon Christof » 10. November 2013 14:17
Yes, the shown cylinderhead has to be fitted with a cylinder without centerring.
Beitragvon mario1300 » 13. November 2013 00:08
OK,just a few questions :P
The area marked with red is lower than the area marked with blue colors...WHY?
For cooling maybe?
The same pattern on some older Mz cylinderheads:
Has anyone sucessfully modified TS Cylinder with ring(like mine from 76) and installed it with original ES cylinderhead on ES 250/2 Engine??(The links you gave me are great but my translator /bing/google doesnt always translate in a meaningfull way...)
What about height/location of intake and exhaust channel on this 2 different cylinders(71 and 76)?Does it vary?
If I removed the ring precicly and installed a spacer with the same thickness as ring...?
mario1300
Beitragvon mario1300 » 9. Dezember 2013 00:57
Thank you guys for answering.This problem is solved,the engine is almoust finished.
Another question is related to aft Hinterradschwinge/rear swing arm and its Lagerbolzen/bearing bolt...How to remove it when it doesnt wanna go out???All the years without lubrication and bad care of motocycle from previous owners...
Heating or use force?
mario1300
Beitragvon altf4 » 9. Dezember 2013 02:32
hi -
i'm just about to do the same -
and asked a friend who's a mechanic as he's got a 5 tonne press. can't be asked trying my luck with a hammer and a chisel ;)
these f*ckers sit in there solidly.
the bushes available, at least in my case, come oversized and need to be worked to the correct measure with a reamer.
best, max ~:)
p.s.: got mine from here:
haase
(under fahrgestell/blechteile etc...
82055 Lagerbuchse für Schwingenbolzen
http://www.alteisentreiber.de
altf4
Beitragvon mario1300 » 24. November 2014 21:46
Still few tweaks to adjust,but this is current state of my MZ
mario1300
Beitragvon altf4 » 24. November 2014 22:29
...very kewl! nice one!1!!
g max ~:)
altf4
Beitragvon mario1300 » 20. März 2015 21:48
Waiting for some parts :twisted:
The red seat cover is gonna be installed+ baggage carrier/porter and small black and white suitcase :mrgreen:
BIG THANKS to Mr_T and Spitz :bia: :bia:
mario1300
Beitragvon mario1300 » 23. März 2015 00:14
Since this is a topic about differences between/in mz cylinders...and it is in English
Are TS 250/1(5 speed) and ts 250 4 speed(or ets,es 250) cylinders interchagable??
Thank for answer :twisted:
mario1300
Beitragvon Spitz » 23. März 2015 13:26
:oops: :oops: :oops:
8)
Zuletzt geändert von Spitz am 22. April 2015 21:16, insgesamt 1-mal geändert.
68er Gespann- Trophy
www.reise-laster.de
Generation Rechenschieber :-)
Spitz
Themen: 170
Beitragvon mario1300 » 20. April 2015 12:06
65 kilometres trip on a rainy day :twisted: :mrgreen:
mario1300
Beitragvon kutt » 20. April 2015 12:08
... with the car :D
AmForumSchrauber
Mr. Kardan
Themen: 597
Beitragvon mario1300 » 19. Mai 2015 11:53
With red seat installed :D
mario1300
Beitragvon mario1300 » 16. Juli 2015 23:32
My precious :twisted: :mrgreen:
mario1300
Beitragvon mario1300 » 22. September 2015 16:12
Yay or nay(looking good or not) :twisted: ?
mario1300
Beitragvon Hubert » 22. September 2015 19:39
Looking good. Hubert
Hubert
Re: Mz es 250/2 Garage
Beitragvon mario1300 » 26. Dezember 2015 16:09
Little bit of warm up:
https://www.youtube.com/watch?v=EjOEnQB ... e=youtu.be
Still have to install few things;new H4 lamp and few crome items(Thanks Guessi) and new Trophy stickers/decals(Thanks Stefan) :mrgreen:
mario1300
Beitragvon mario1300 » 28. Januar 2016 00:09
All the parts listed in last message/post installed
+digital tacho/rpm and hour counter...functionality over looks ;)
mario1300
Beitragvon mario1300 » 30. April 2016 23:17
mario1300
Beitragvon 990sm-r » 11. Mai 2016 02:42
ich Fahre eine ES/ 250
990sm-r
Zurück zu Questions and Answers
