Aktuelle Zeit: 19. November 2025 04:19
 Betreff des Beitrags: Oil/petrol mix
BeitragVerfasst: 20. Mai 2020 13:31
Good afternoon everybody!
I have just taken my beautiful 1954 IFA RT125/1 for the first run of the year with gentle wisps of 2-stroke in the breeze.......The petrol/oil mix is 25:1 (as standard) but I have seen some recent discussions on other forums that state "modern oils are much better quality these days so in some cases, the mixture ratio can be altered"
What are members feelings concerning this?
Could my RT run on 33:1? I am curious about this as I think there may be a risk of piston seizure, and in addition to this, even if the bike is used every day, you would only save a small amount of money.
I think I would be reluctant to change the ratio as unfortunately in England, we do not have the wonderful range of places to buy RT spares as you lucky people in Germany have!
Kind regards, Neil
Fuhrpark: 1954 RT125/1, 1955 BK350, 1960 IWL SR59 Berlin, 1960 IWL Campi, 1976 TS250, 1977 TS250, 1994 HD MT500, 2000 Yamaha YP250, 2002 HD Sportster, 2015 HD Roadglide Special
 Betreff des Beitrags: Re: Oil/petrol mix
BeitragVerfasst: 20. Mai 2020 15:59
Bilder: 19
Hello Neil,
piston seizure would be my least concern. With modern 2-stroke oils, the lubrication provided by 1:33 or even 1:50 mixture should be more than enough, i.e. if it seizes, there must be another reason, 1:25 would not have prevented it.
Some people claim that the wrist pin bearing only being an bronze bushing demands 1:25 and needle bearings would be required for 1:50. However, other engines with bronze bushings are specified for 1:50 by their manufacturers, e.g. early Vespa 50 and Vespa Primavera models by Piaggio.
Saving money is probably not the main incentive for leaner mixtures. Less smoke and smell may be reason enough to give it a try. My personal opinion is that 1:33 should definitely work, and 1:50 should also not cause any issues if the engine is in good condition and not pushed too hard. No warranties though, try at your own risk. ;)
Cheers,
Felix
Fuhrpark: MZ TS 125
BeitragVerfasst: 20. Mai 2020 16:32
Themen: 275
Hi Neil,
one questions ... thousands of (possible) answers. You are right it´s not about to save money because of a smaller oil consumption.
Contrary to that many drivers use the best (=most expensive) oil for their dearly-loved toys. Only the question remains: Can less oil
be better for my motorcyle or not. We know: too less or no oil at all will cause motor demage for sure - too much oil leads to
problems with sparkling plug and pollutes piston, crankcase and exhaust. The optimum lays anywhere between ...
The prescribed 1:25 comes from the 50ies state-of-the-art used oils and used sliding bearings (piston), needle bearings (lower rod)
and ball bearings (if crankshaft bearings aren´t lubricated by gear oil). And the mixture must be good for infinite maximum power.
To keep your system clean is a good aim. Try yourself to reduce the mixture down to 1:33 bit by bit over a long time span.
Listen inside your motor while driving - watch abnormal noise. Driving mainly 2/3 of maximum power only for pleasure is a good
reason to lower the oil amount. If the oil is better today than in the fifties of the gone century is highly supposed - but
nobody can really prove it by data. Long-term professional tests are impossible (who gives voluntarily 10 brand new RT125-motors
to a laboratory to ruin them ...?).
1:25 means 40ml oil per litre. If your RT needs 3l/100km the absolut oil consumtion is 120ml/100km (please, convert to miles an gallons by yourself :mrgreen:).
1:33 means 30ml oil per litre. If your RT needs 4l/100km you have an oil consumption of 120ml/100km, just the same as a 1:25 driver
whose RT needs only 3l/100km.
All depends from all things - but you see, howver, it´s all tight close.
I drive my ETZ150 since 15 years with 1:100. Motor and exhaust stay clean and no problems was visible while general overhaul.
Kind regards
Die google-Rückübersetzung lieferte folgende literarische Kostbarkeit:
Hallo Neil,
eine Frage ... Tausende von (möglichen) Antworten. Sie haben Recht, es geht nicht darum, wegen eines geringeren Ölverbrauchs Geld zu sparen.
Im Gegensatz dazu verwenden viele Fahrer das beste (= teuerste) Öl für ihre geliebten Spielzeuge. Es bleibt nur die Frage: Kann weniger Öl
sei besser für mein Motorrad oder nicht. Wir wissen: Zu wenig oder gar kein Öl führt mit Sicherheit zu Motorschäden - zu viel Öl führt dazu
Probleme mit der Zündkerze und verschmutzen Kolben, Kurbelgehäuse und Auspuff. Das Optimum liegt irgendwo zwischen ...
Die vorgeschriebene 1:25 stammt aus den 50er Jahren nach dem Stand der Technik Altöle und gebrauchte Gleitlager (Kolben), Nadellager (untere Stange)
und Kugellager (wenn Kurbelwellenlager nicht mit Getriebeöl geschmiert sind). Und die Mischung muss für unendliche maximale Leistung gut sein.
Es ist ein gutes Ziel, Ihr System sauber zu halten. Versuchen Sie, die Mischung über einen langen Zeitraum Stück für Stück auf 1:33 zu reduzieren.
Hören Sie während der Fahrt in Ihrem Motor zu - beobachten Sie ungewöhnliche Geräusche. Es ist gut, hauptsächlich 2/3 der maximalen Leistung nur zum Vergnügen zu fahren
Grund, die Ölmenge zu senken. Ob das Öl heute besser ist als in den fünfziger Jahren des vergangenen Jahrhunderts, wird hoch vermutet - aber
niemand kann es wirklich durch Daten beweisen. Professionelle Langzeittests sind nicht möglich (wer freiwillig 10 brandneue RT125-Motoren gibt
in ein Labor, um sie zu ruinieren ...?).
1:25 bedeutet 40 ml Öl pro Liter. Wenn Ihre RT 3 l / 100 km benötigt, beträgt der absolute Ölverbrauch 120 ml / 100 km (bitte rechnen Sie selbst in Meilen pro Gallone um :mrgreen:).
1:33 bedeutet 30 ml Öl pro Liter. Wenn Ihr RT 4 l / 100 km benötigt, haben Sie einen Ölverbrauch von 120 ml / 100 km, genau wie ein 1:25 Fahrer
dessen RT benötigt nur 3l / 100km.
Alles hängt von allen Dingen ab - aber Sie sehen, es ist alles eng.
Ich fahre meine ETZ150 seit 15 Jahren mit 1: 100. Motor und Auspuff bleiben sauber und bei der Generalüberholung waren keine Probleme sichtbar.
BeitragVerfasst: 20. Mai 2020 17:57
As long as bushings are mounted in the conrods' smallend, you better should not use oil lower than 1:33.
In my TS250/1 (needle bearing) I use 1:70 semi-synth oil.
Cheers,
Hans
BeitragVerfasst: 20. Mai 2020 21:41
Hi there everyone
Many thanks for all the information! The only question now is....Do I have the nerve to change the petrol/oil ratio to 1:33?
As my RT has not been used for a while due to the covid-19 pandemic, I’ll run it for a while and keep checking the spark plug.
Many thanks again to everyone for the information!
Kind regards, Neil
