Aktuelle Zeit: 23. August 2025 23:58
BeitragVerfasst: 15. Februar 2011 22:04
Hello,
1964 MZ es175 / 1 for, Bing carburetor, whichever is appropriate?
1- http://www.ost2rad.de/MZ-Ersatzteile/Ve ... TZ125.html
2- http://www.ost2rad.de/MZ-Ersatzteile/Ve ... TZ150.html
3- http://www.ost2rad.de/MZ-Ersatzteile/Ve ... TS150.html
I´ve changed the subject for more and better answers, Lothar
1964 MZ es175/1
 Profil Persönliches Album
 Betreff des Beitrags: Re: MZ es175/1 - Bing carburetor
BeitragVerfasst: 1. März 2011 21:35
for your help, thank you very much...
1964 MZ es175/1
BeitragVerfasst: 2. März 2011 08:44
Hi mexec,
I don´t know why noone answered!?!? But sometimes Threads are going that fast to the basement, that noone recognizes them.
Belonging your problem: As far as i know, there is no chance to get a Bing for the ES175. Your ES needs a 26mm carburetor, but Bing only delivers 24mm or 30mm. You should try to get a BVF 26mm carburetor.....for that you should have a look on ebay.de or post a search on the forum. Maybe you could ask Güsi: www.mzsimson.de or Gabor: www.brockolow.de
I hope that will help you fixing your ES.... if not...post again or write a personal mail and I will try to help you....
Greetz Friesenjung
Fuhrpark: MZ ETZ 250 Bj.88 / MZ ETZ 250 Bj.82(teilzerlegt) / Schwalbe KR51/1(in Warteschleife) / Bocas MX40/8 / Liegerad Nirosta-Eigenbau
BeitragVerfasst: 2. März 2011 09:29
I think some of our experts are not that familiar with English. I'll translate it shortly:
Mexec will wissen welcher der von ihm verlinkten Bing vergaser für seine ES 175 taugt.
In general I would agree with Friesenjung. I had a look on the homepage of the manufacturer, and there is a carburetor with Ø26mm SEE HERE.
I think this should fit, but maybe you need to change the nozzles/blast pipes/injector (whats the correct word for that? there are to many ^^ ).
Frage an die "Eggschberten": muss man nur auf den Querschnitt achten beim 26er Vergaser von Bing und die dazu gelieferten düsen passen oder muss man die entsprechend anpassen? Passt der überhaupt? helft ihm ;) auf Deutsch oder Englisch ich oder wer anders (in der not auch der Gockel-translator) übersetzt gern.
Hopefully some more will answer ;)
regards Henry
Fuhrpark: ehemals: MZ ES 250/1 Baujahr: 1964 leider geklaut worden, nur Tank liegt noch zum entrosten im Keller. wer einen Rahmen mit Fahrgestellnummer 1214318 oder Motor mit 2237911 oder suspekte teile Angeboten bekommt, kann sich gern bei mir oder der Polizei melden.
BeitragVerfasst: 2. März 2011 14:57
Themen: 269
Was sollen wir nun unseren türkischen MZ-Fahrer mexec raten?
Ich habe zwar keine 175/1 aber denke, dass 24mm Durchlass beim Bing zur Not (normal wären 25,5mm) gehen würde,
wenn der Vergaser überhaupt auf den Ansaugstutzen drauf geht.
Die Bedüsung müsste dann sicher noch etwas verändert werden. Also, wie groß ist der Ansaugstutzendurchmesser zum Aufklemmen
des Vergasers bei der 175/1 und kriegt man den Vergaser dort drauf? Soweit ich mich erinnere, ist bei dem Bing 53 eine Art
Pertinaxring eingelassen, den man notfalls aufbohren könnte.
@mexec: Be patient, please, some internal discussion will help to find a high-quality answer ...
BeitragVerfasst: 2. März 2011 15:01
Themen: 140
nächstes Problem, passt die Vergaserabdeckung dann noch drauf?
BeitragVerfasst: 2. März 2011 15:14
Themen: 269
der janne hat geschrieben:
Gute Frage, ich befürchte: nein.
BeitragVerfasst: 2. März 2011 15:28
Ich bin ma so frei und übersetz das stück schon:
translation of the above notes:
lothar hat geschrieben:
He thinks that the Ø24mm bing could work but maybe not properly.
At least he sais, the nozzles need to be changed for proper working. But the next problem is whether this carburetor fits to the adapter to the cylinder.
Lothar remembers that there schould be a ring of (i didn't knew this material until 5 min ago ^^) pertinax which could be drilled out.
next is, does the hood/blanking still fit then?
And if it fits, you will have one aditional hole beside the Bing at least. Because it's a central float gauge, the BVF is a side float gauge i think.
BeitragVerfasst: 2. März 2011 15:35
Themen: 269
Henry hat geschrieben:
Right, my dear ...
BeitragVerfasst: 3. März 2011 19:40
hello,
Thank you for your answers;
my extra, have the carburetor cap (Vergaserabdeckung) and suction pipe (ansaugstutzen)
I make changes on.
cracked my original carburetor (BVF 25.5 KN 1-2) hollow slide (hohlschieber)
-- Hinzugefügt: 3/3/2011, 20:02 --
Is separated from the inner tracks?
I think I may be disconnected..
1964 MZ es175/1
BeitragVerfasst: 3. März 2011 21:16
Oh, the round-slide carburetor looks realy badly cracked. How did you do this? Did you have an accident?
mexec hat geschrieben:
Do you ask for drilling out from the inside on which the arrow shows? Well I think there is now other posibility. I wouldn't do changes on the suction pipe because maybe in futur you get a BVF again and then you would need this suction pipe.
Nevertheless, if you find a solution please show us how you did it, because some of us may have the same problems. And if you have further questions feel free. We'll do our best. :ja:
BeitragVerfasst: 3. März 2011 23:06
no, I did not accident.
stuck in the carburetor
cracked, while trying to remove .
I've found an answer
53/24/201 I think it appropriate carburetor
http://www.bingpower.de/forum/viewtopic.php?f=1&t=184
1964 MZ es175/1
BeitragVerfasst: 4. März 2011 08:08
Themen: 197
Bilder: 34
wernermewes
Man sollte einfach keinen Bing an diese schönen alten Maschinen bauen :!: :!:
Hier ist einfach original angesagt, oder etwa nicht :?:
allen immer eine gute Fahrt
wernermewes
MZ und Simson Sammler
und eine Jawa CZ 175
BeitragVerfasst: 4. März 2011 08:28
Themen: 269
wernermewes hat geschrieben:
Wenn du dort wohnen würdest, wo mexec wohnt, und die ES laufen soll, würdest du das möglicherweise anders sehen...
(If you would live there where mexec lives and you want your ES run you would be of another opinion maybe... )
BeitragVerfasst: 4. März 2011 09:16
Themen: 140
ich hätte aber passende Ersatzteile für seinen Vergaser da?
Vielleicht ist das die Lösung??????
BeitragVerfasst: 4. März 2011 09:38
Themen: 269
@mexec: Janne wrote that he has some spare parts for your original BVF carb available. Are you interested?
BeitragVerfasst: 4. März 2011 15:52
Lothar: Thank you for translation help.
yes I am interested in,
But you have round-slide (hohlschieber)?
my carburetor BVF 25,5 KN 1-2.
How much would you price?
For your interest, I would like to thank everyone..
1964 MZ es175/1
BeitragVerfasst: 4. März 2011 18:09
Drivers helping Drivers ;) I think we are all pleased when we could help.
BeitragVerfasst: 4. März 2011 19:01
thank you very much, well be that mz-forum..
1964 MZ es175/1
BeitragVerfasst: 4. März 2011 19:13
CikaDule
Offtopic:
Ja, ich bin auch begeistert um die Bereitschaft den Forenmitglieder zu helfen!!! Ihr seit tolle Kamaraden!
Yes, I am delighted too, with the readiness of forum members to always help!!! Guys you are great comrades!
:respekt: :respekt: :respekt: :flehan: :flehan: :flehan:
Fuhrpark: ETZ 250 Bj. '88.
BeitragVerfasst: 4. März 2011 21:13
Themen: 140
you´re welcome, I found the parts for him, everything is fine! :D :D :D :D
BeitragVerfasst: 4. März 2011 21:18
:gut:
Mitglieder in diesem Forum: Steffen G und 333 Gäste
