turbinee hat geschrieben:It has the round circlip below the hohlschrauben and I removed it trough the small round hole on the side of the shock's body, and that's it.
Yesturbinee hat geschrieben:So I should remove the grease nipple first and then just pull to get it out?
Not correct, you have to use M10x65turbinee hat geschrieben:Ok, and for the assembly I just need to compress the shock and get the bolt in. How about the size of the bolt, is 8mm correct.
, you have done some pictures bevore start restortion? When the motorcycle was manufactured? The officially number of manufactured MZ125/4 is 4904 pices, non of these officially exportet to Bulgaria
turbinee hat geschrieben: I just covered the last digits and left only the first four visible.
turbinee hat geschrieben:I,ve assembled the front suspension and will post the pictures soon.
[attachment]file name[/attachment]
Mitglieder in diesem Forum: Baidu [Spider], Guzzi44 und 42 Gäste
