Aktuelle Zeit: 10. Februar 2026 04:32
BeitragVerfasst: 11. November 2010 20:50
Both my SilverStars have this unit. I think it's called a RF Supression module to prevent radio interference. It's wired to the CDI unit, and is not on my German wiring diagram. Is this piece on export MZs only, and can I bypass it? Danke all.
-Donny
Fuhrpark: 1-3/4 1995 MZ Silver Star
 Betreff des Beitrags: Re: What is this?
BeitragVerfasst: 11. November 2010 21:53
Donny,
it's a circuit that prevents the electric starter works when the engine ist already running.
So you may remove it.
BeitragVerfasst: 11. November 2010 22:10
Thanks Nordtax. It has three wires, braunes/weißes, schwarzes/weißes, and braun. Braunes/weißes goes back to the ignition switch. When the key is in the OFF position, the braunes/weißes wire is shorted to ground. The braunes/weißes wire is also spliced to the schwarzes/weißes wire that goes to the ignition CDI module. So when he ignition switch is turned OFF it stops the engine.
But I do not see how it affects the electric starter. Bild Maybe I am stupid?
-Donny
BeitragVerfasst: 11. November 2010 22:22
Donny, it should be connected also to the starter relay, i will look for the exact wiring next days.
BeitragVerfasst: 11. November 2010 22:42
Thanks. :mrgreen: Berni or Urs, if you will, please translate my question. I would really appreciate it. The few of us in the US who have Rotax MZs are curious about this circuit and suspect it may be the cause of why the engine will not shut off with either the key or the KILL switch.
There is so much MZ knowledge here on this forum so I'm sure one of the electrical gurus will know the answer.
-Donny
BeitragVerfasst: 12. November 2010 08:42
Themen: 279
Hi Donny
as far as I know the used ignition box could produce unwanted sparks as consequence of
glitches or spikes which were produced and propagated by switching load circuits especially the starter relay.
That means it was possible with a small probabilty that any irregular sparks could reverse the
rotation of the crank and could give a killing beat to the starter free-wheel.
To prevent such electrical spikes from the ignition control box input these components were added.
All this shows how chaotic this technical development ran some months after the wall came down and MZ was
pressed to defend their position on the market.
Here is the technical letter from MZ including the construction manual which was sent to all MZ work shops:
I purchased the set because I had an MZ500R in 2002 which hadn´t it. If I remember correctly the set was about 25 EUR.
Analyzing the set I found components of about 1 EUR within... :cry:
The photos show the new set and how it was inserted in my MZ500R:
The red components were added in the following part of the electric scheme
That´s all what I know about.
Kind regards
BeitragVerfasst: 12. November 2010 18:53
Thank you Lothar. This explains it's purpose perfectly, especially the schematic. I think I will keep it installed. Bild
lothar hat geschrieben:
If I remember correctly the set was about 25 EUR. Analyzing the set I found components of about 1 EUR within...
That's how they do things here too. :mrgreen:
-Donny
BeitragVerfasst: 17. September 2011 20:46
Bei meiner Rotaxe ist das Enstör-Set nicht verbaut. Was soll es konkret bringen?
Fuhrpark: ETZ 150/89, RC42/96
BeitragVerfasst: 19. September 2011 06:46
Themen: 279
Charly hat geschrieben:
...as far as I know the used ignition box could produce unwanted sparks as consequence of
BeitragVerfasst: 19. September 2011 16:33
@lothar
Nicht jeder kann Englisch.
Rudi
Fuhrpark: _
MZ TS 250/1
MZ TS 500 R (m. SEL)
MZ ETS 500 R (m. Velorex)
MZ 500 R (Polizei)
MZ Silver Star Classic 500
MZ 500 Voyager (zerlegt)
BeitragVerfasst: 19. September 2011 17:07
In der Kurzfassung: Das Set soll verhindern das der Anlasser durch unerwünschte Spannungspitzen, die im Bordnetz auftreten können, ungewollt in den laufenden Motor "einstartet", was unweigerlich zu Schäden führen dürfte...
BeitragVerfasst: 19. September 2011 17:46
naja so ganz korrekt übersetzt ist das nicht, lothar mein, dass es durch diese fehlfunken in einem ungünstigen ZZP zur umkehr der drehrichtung der KW kommen kann, dabei würde unweigerlich die kraft des motors sofort auf den anlasserfreilauf übertragen werden, was ihn schnell zerstören kann.
BeitragVerfasst: 20. September 2011 06:22
Themen: 279
MZ-Rotax-Rudi hat geschrieben:
@lothar
:oops: Tut mir leid, du hast Recht. Ich las die Wörter "Set" und "Sevenfity"(?) in seinem Beitrag und dachte, ... naja, er hat´s nur übersehen weiter oben.
BeitragVerfasst: 15. Oktober 2011 21:43
Dieser Entstörkitt hatt ja nun allgemein für einige Fragen gesorgt.
Mir ist bis heute nicht klar welche Spannungsspitzen abgebaut werden sollen. Am Anlasserrelay eine Diode zu instalieren ist für mich nachvollziebar und notwendig. Dort können/müssen induktive Spannungspitzen erzeugt / abgebaut werden.
Warum wird aber ein Kondensator und Widerstand zwischen Motorstopschalter und CDI gefriggelt?
Weiß jemand darauf eine Antwort?
Fuhrpark: 500Fun
BeitragVerfasst: 17. Oktober 2011 06:56
Themen: 279
Memme250 hat geschrieben:
Weil diese Leitung offensichtlich wie eine Antenne für Störimpulse auch von beliebigen anderen Quellen dient.
Bei derartigen Problemen müssen immer ZWEI Wege verfolgt werden,
1. Dämpfung an bekannten Störaussendern UND 2. Dämpfung vor potenziellen Störempfängern.
BeitragVerfasst: 17. Oktober 2011 14:51
I think the component values of the resistor/capacitor (R/C network) is tuned to suppress the frequency of the noise pulses.
-Donny
BeitragVerfasst: 17. Oktober 2011 15:19
Themen: 279
Donny hat geschrieben:
Yes, Sir...
BeitragVerfasst: 19. Oktober 2011 21:13
Danke Lothar,
Du meinst also,das Verhältnismäßige(für uns nicht meßbar) geringfügigige Spanungsschwankungen/ die CDI zu unkontrollierten Zündimpulse animiert?
Gefühlsmäßig könnte ich es so bestätigen. Das erscheint mir als eine logische Erklkärung ,zu den viel zu oft ,unerwarteten Absterben des MZ-Rotaxmotors.Da gibt es zwar noch einige andere Faktoren ,aber das passt ,was Du sagst!
Danke.
Fuhrpark: 500Fun
BeitragVerfasst: 20. Oktober 2011 06:43
Themen: 279
Die Aussage ist richtig, aber geringfügig sind die in der Regel überhaupt nicht. Bei Schaltvorgängen mit induktiver Last
(ist ja das Prinzip der Zündspule) kommt es zu Spannungsspitzen bis in den kV-Bereich. Die sind nur extrem
kurz (Größenordnung 1µs und darunter) und sind deshalb mit Garagen-Geräten nicht/kaum messbar.
Ich hatte mal in einem Arbeitsraum an einer 220V-Steckdose 12kV/0,8µs gemessen, wo mit einem etwa 8m entfernten Lichtschalter
ein Leuchtstofflampen-Band eingeschaltet wurde.
BeitragVerfasst: 21. Oktober 2011 22:27
Ja Lothar ,das mit dem Leuchmittel glaube ich Dir. Schön das es hin und wider logische Erklärungen gibt. Ich habe keine Zweifel mehr. Bei den Mz-Rotaxen passieren je nach Kabelverlegung/konfiguration tatsächlich unglaubliche Betriebszustände, ähnlich wie Du es für den Arbeitsraum/Leuchtstofflampe Beispielhaft beschreibst.
Was meinst Du? Welche Kabel gehören nicht Zusammen verlegt oder noch besser (abgeschirmt) verlegt? Ne, ich will es auch nicht übertreiben, aber der Gedanke, könnte doch Kondensator und Co ersetzen.( ich habe an meinen beiden MZ-Rotaxen keine Enstörsätze)
PS: Das Thema interessiert mich darum so ,weil ich seit kurzem eine Rotax KTM im Stall habe und die MZ- Zickerreien nicht wirklich bei der KTM feststellbar sind. Dafür Eselt aber die KTM bei anderen Sachen. :lol:
Fuhrpark: 500Fun
BeitragVerfasst: 22. Oktober 2011 10:22
Themen: 108
Wo hat denn deine KTM das Anlasserrelais? Dran bleiben - klingt interessant und plausibel
Edit sagt: an meiner schon immer gut laufenden Country, liegt das Anlasserkabel links vom Zylinder unter dem Riementrieb verlegt.
An der anderen ist es mit den Kabeln von Zündung und Lichtmaschine geführt.
Grüße Kay
Infos zum MZ 125ccm 4 Takter
Fuhrpark: ETZ 251, 250,
MuZ 500 FW
MZ ETZ 251 Lastengespann
MuZ 500 Country
1000 SF
ES 175/1 (Luise)
MZ SM 125 / MZ SX 125
Baghira SM Bj 2008
ETZ 301
BeitragVerfasst: 23. Oktober 2011 20:40
mzkay hat geschrieben:
Gute Frage Kay!?
Des Pudels Kern haben wir scheinbar erkannt. :idea: An den Maschinen wo die Kabel getrennt verlegt sind oder kein Anlasser vorhanden ist gibts anscheinend keine Diskussionsgrundlage.
So trennt sich die Spreu vom Weizen. Gut das wir darüber sprechen. :D
Das spricht mal wieder für die Schnelle Mache Fix Konstruktion der MZ500R.Leider. :oops:
Für mich sieht die Nachrüstaktion als eine wirksame Verschlimmbesserung aus = Problem erkannt und gleichzeitig neue Probleme eingebaut.
Fuhrpark: 500Fun
BeitragVerfasst: 24. Oktober 2011 08:55
Themen: 108
Die Lorbeeren gehören dir und Lothar - ich bin doch nur durch euch drauf aufmerksam gemacht worden.
Ist es richtig, dass deine KTM keinen Anlasser hat? Dann sollte es doch beinahe ausreichend sein, dass bei Problemrotaxen das Anlasserkabel bis zum Relais entfernt wird.
Wobei man immer wieder sagen muss, dass die Rotax MZ sehr sehr eigenwillig reagiert. Irgend etwas ist ja immer.
Dennoch wäre es wirklich interessant, welche Kabel völlig überflüssig wären, wenn man denn die KAbelbäume optimiert oder teilweise schirmt.
Ich hätte ne Lust an meiner FW-Rotax einen neuen Kabelbaum zu stricken. Wobei diese widerrum mit zusatzelektronik vollgepackt ist.
Grüße Kay
MuZ 500 FW
MuZ 500 Country
1000 SF
ES 175/1 (Luise)
Baghira SM Bj 2008
ETZ 301
BeitragVerfasst: 2. November 2011 03:20
Yes, I thank Lothar very much. Many MZ 500 owners in the States have questioned me regarding the surge suppressor circuit, and I have referred all to Lothar's very excellent post. All the US MZ500's do have the Resistor/Capacitor RC filter network wired in, but none have the diode circuit across the relay, including my two Silver Stars. So, perhaps MZ engineering later determined not to include the diode on the export models? I don't know if the diode circuit is needed? Perhaps for additional reverse current protection I think?
-Donny
BeitragVerfasst: 2. November 2011 08:39
Themen: 279
The diode circuit is needed when you have other components close to the relay which are more sensitive to voltage glitches/spikes
as they should usually be. Applying a so-called self-induction recuperation diode is a standard circuit technology.
Low-power relays have them often integrated in their case. When you switch off a relay-coil you get the same result
as if you do it with an ignition coil by a contact breaker: high voltage peak. The diode simply clamps this peak ...
Regards
BeitragVerfasst: 2. November 2011 15:00
Thank you once again Lothar for the explanation. A clamping diode. I remember now that term and it's applications from my electronics schooling many many years ago.
-Donny
BeitragVerfasst: 25. Februar 2017 11:21
Ich schon wieder mal als Leichenschänder :oops:
Nun habe ich einen Woche lang jeden Abend an meiner Rotax verbracht um den Kabelsalat zu ordnen.
Schaltpläne zusammen gesucht , Kabel zugeordnet, viel seltsame Dinger gefunden unter anderen dieses Entstör Ding.
Da ich nicht wusste was das ist und zwei Kabel schon so gut wie ab waren, habe ich es vorsichtig aus gepackt. Das war mir dann zu heikel und ich habe nur neue Kabel angelötet.
Dann bin ich auf die Diode gestoßen die parallel am Anlasser Relais eingebaut ist, bei mir sind es sogar zwei.
Und gestern Abend hat der Dorni mir das einfach verlinkt, so ist das wenn man keinen Google Führerschein hat :( , das hätte mir viel Zeit gespart. Vielleicht sollte man das in der Wissensdatenbank verlinken. Ich will damit sagen wenn man nicht weiß was man suchen soll ist es echt schwer was zu finden. :mrgreen:
Hier ein Bild von meinen Entstör Set.
@ Lothar, hast du den Schaltplan auch komplett ?
Suzuki 1000V
