Herstelldatum Date of manufacture
For non German-speakers. We will try to discuss in your language here, preferably in English. Guest posts welcome.
Beitragvon bikerbrom » 8. Dezember 2011 11:54
Herstelldatum
Date of manufacture
I have an ES250/2. My problem is that the date of manufacture is unreadable on the plate riveted to the front forks.
Does anyone have access to a database showing frame numbers by date of manufacture?
Ich habe ein ES250/2. Mein Problem ist, dass das Herstelldatum auf der Platte unlesbar ist, die zu den vorderen Gabeln befestigt wird. Hat jemand Zugang zu einer Datenbank, die Rahmenzahlen bis zu Herstelldatum zeigt?
Fuhrpark: MZ TS250/1975, MZ saxon/1997, MZ ES250-2
bikerbrom
Re: Herstelldatum Date of manufacture
Beitragvon kutt » 8. Dezember 2011 12:01
the frame-/enginenumber might help ;)
Themen: 598
Beitragvon Ralle » 8. Dezember 2011 13:32
If the framenumber is also unreadable at the plate you can find it rear on frame, imprinted at the holder for rear fender. In a few cases it is imprinted at the frame near the front engineholder at the right side.
The enginenumber is placed at the crankcase right behind cylinder...
Ralle
Beitragvon bikerbrom » 8. Dezember 2011 16:21
OK, I'll look at it later today.
-so far I've found out that the chassis numbers for the ES250/2 are as follows:
1969-1973
1430874 to 1500000
1967-1969
1300001 to 1430873
-- Hinzugefügt: 9. December 2011 01:18 --
My frame number was where Ralle indicated:
14266** in other words, between 1967 and 1969.
I'm guessing it must be late 1968 to early 1969, but there any way of finding the precise date?
bikerbrom
Zurück zu Questions and Answers
