Ralle hat geschrieben:Some days ago you had written questions about a PVL- ignition installation, now you has changed to Powerdynamo? If yes, there is installed only the ignition or the complete alternator with integrated ignition? There is a battery on bord?
Also some days ago you had written about exchanging the backlight, which of them is installed now?
pepin1234 hat geschrieben:so I need to know how test the Vape regler without start the engine??
) should be ok. You have to check also black to black and not brown to black Ralle hat geschrieben:pepin1234 hat geschrieben:so I need to know how test the Vape regler without start the engine??
Regulator: I guess a regulator test with measurements outside the system is impossible. But you can smell on the regulator, if it has an burnt smell you know that it was destroyed![]()
Another possibility could be, to plug the regulator into another running system.
Stator: If I see values from Powerdynamo for ignition coils, I mean your measured values for brown to red and brown to yellow (Powerdynamo said white) should be ok. You have to check also black to black and not brown to black
Lorchen hat geschrieben:Mit Batterie funktioniert das Bremslicht wie bisher. Hast Du die Minimalvariante der Vape ohne Batterie eingebaut, muß der Motor natürlich laufen, sonst gibt's keinen Strom an Bord.
wernermewes hat geschrieben:Lorchen hat geschrieben:Mit Batterie funktioniert das Bremslicht wie bisher. Hast Du die Minimalvariante der Vape ohne Batterie eingebaut, muß der Motor natürlich laufen, sonst gibt's keinen Strom an Bord.
Richtig
