VAPE Bremslicht
VAPE Bremslicht
Beitragvon pepin1234 » 8. Dezember 2011 13:12
hallo ich habe kein Bremslicht mit der Zündung VAPE. Ich habe den Motor drehen? zu haben, Bremslicht? Ich installiere die Zündung VAPE
Viva Cuba Libre!!!!
Fuhrpark: MZ ETZ 251/1990, MZ 1000 S/2005, ...
pepin1234
Re: VAPE Bremslicht
Beitragvon Lorchen » 8. Dezember 2011 13:15
Mit Batterie funktioniert das Bremslicht wie bisher. Hast Du die Minimalvariante der Vape ohne Batterie eingebaut, muß der Motor natürlich laufen, sonst gibt's keinen Strom an Bord.
Re: VAPE Bremslicht
Beitragvon Ralle » 8. Dezember 2011 13:56
Some days ago you had written questions about a PVL- ignition installation, now you has changed to Powerdynamo? If yes, there is installed only the ignition or the complete alternator with integrated ignition? There is a battery on bord?
Also some days ago you had written about exchanging the backlight, which of them is installed now?
Ralle
VAPE Bremslicht
Beitragvon pepin1234 » 11. Dezember 2011 20:02
Ralle hat geschrieben:Some days ago you had written questions about a PVL- ignition installation, now you has changed to Powerdynamo? If yes, there is installed only the ignition or the complete alternator with integrated ignition? There is a battery on bord?
Well I really liked set the PVL because I can use it with a electronic Drehzahlmesser. The PVL I bought in ebay and I was not sure did work, so I install the PVL and I had always a very low voltage making the test ignition from the yellow cable to ground. I supposed the pvl ignition was broken so I desided install again my Vape system. after intall the Vape I have a little doubt about where set the black cable of the relays ( because the very bad schaltplan of powerdynamo ) then I desided set the black cable to the blak/red ingnition cable, so I do. With these set up I test performance of the motorcycle and all was ok less the Druckknopf für Lichthupe. That was not so important for me and I decided put the engine on. the engine startet just 2 seconds and the electric system shut down. So I open the Druckknopf für Lichthupe and I see the white cable broken and I desided separate from the system this switches just to try again the ignition system. then I try again but the short remains. Now I have a malfuntion in the electric system.
My Stator test:
I disconected all the wires of the stator to messen and have, brown with bouth black wires a non conductivity, brown with red 0.504 Kiloohmios and brown with yelow 0.07 Kiloohmios. I guess is broken but not sure.
so I need to know how test the Vape regler without start the engine??
Viva Cuba Libre!!!!
pepin1234
Re: VAPE Bremslicht
Beitragvon Ralle » 12. Dezember 2011 07:19
pepin1234 hat geschrieben:so I need to know how test the Vape regler without start the engine??
Regulator: I guess a regulator test with measurements outside the system is impossible. But you can smell on the regulator, if it has an burnt smell you know that it was destroyed :ja:
Another possibility could be, to plug the regulator into another running system.
Stator: If I see values from Powerdynamo for ignition coils, I mean your measured values for brown to red and brown to yellow (Powerdynamo said white :gruebel: ) should be ok. You have to check also black to black and not brown to black :idea:
Ralle
Re: VAPE Bremslicht
Beitragvon pepin1234 » 12. Dezember 2011 14:15
Well ist right that the measurements of the stator brown-red and brown-yelow are well. Just black-black I have not 0.34 Ohm and I got a value of 0.6 Ohm so I suspect I screw so hard the Rotor and maybe is damage the stator. But anyway I get spark in sparkplug but not so satisfied with it.
Before I desmount the rotor to see if is the stator damage I like test something else and I will ask to powerdynamo about the stator black-black value of 0.6 Ohm.
Viva Cuba Libre!!!!
pepin1234
Re: VAPE Bremslicht
Beitragvon wernermewes » 12. Dezember 2011 15:33
Lorchen hat geschrieben:Mit Batterie funktioniert das Bremslicht wie bisher. Hast Du die Minimalvariante der Vape ohne Batterie eingebaut, muß der Motor natürlich laufen, sonst gibt's keinen Strom an Bord.
Richtig :ja:
allen immer eine gute Fahrt
wernermewes
MZ und Simson Sammler
und eine Jawa CZ 175
wernermewes
Themen: 197
Bilder: 34
Skype: wernermewes
Re: VAPE Bremslicht
Beitragvon pepin1234 » 12. Dezember 2011 20:22
wernermewes hat geschrieben:
Richtig :ja:
my variat is with battery. and now I have bremslicht. just I dont get a good spark now. Today I have good news from powerdynamo. The measurement of 0,6 Ohm in my stator is ok. So I have to find what is the problem I cant start the motor.
Viva Cuba Libre!!!!
pepin1234
Mitglieder in diesem Forum: FrankfurterJung und 26 Gäste
