ETZ clutch drag
ETZ clutch drag
Beitragvon Teemu » 25. April 2009 19:17
Hello again
I have had the problem of clutch drag in my bike for a long time. When I pull the clutch lever down the clutch is still "on", it does not release completely. It has bothered me a long time and last time I rode the bike (few years ago) it started slipping.
Now I have replased all clutch plates and springs and took the engine back to the bike hoping for the best. But no luck, the problem is still there. The "Stellschraube" is on use everybit and the center of "Verbindungsstück mit Zugspindel" is 11mm from the engine casing.
I really do not know what else to do. Is there any other way to adjust the clutch?
Otherwise I have to dump the bike to some swamp and buy something japanese instead. Or a bmw. :shock:
edit. sorry I forgot, the springs were not renewed. Maybe they should have been?
Fuhrpark: MZ ETZ 251 1990
Teemu
Re: ETZ clutch drag
Beitragvon Ratzifatzi » 25. April 2009 20:27
Whats the spec of the oil in the gearbox you are using?
If the clutch is working normaly (engaging, dissengaging) and she´s only slipping a bit, often the used oil is wrong. The clutch of the MZ is very sensitiv to the used oil!
Cheers
btw: you doesn´t want to buy a japanese, believe us! :wink:
Ratzifatzi
Re: ETZ clutch drag
Beitragvon Teemu » 25. April 2009 20:44
Hello
The oil I put in the machine (gearbox ofcourse) is a mineral based SAE80W-90, API GL-4.
The problem is that the clutch is not dissengaging properly. Never has done it right. Thats why my clutch plates got glassed badly.
Teemu
Re: ETZ clutch drag
Beitragvon FinnETS » 25. April 2009 22:00
Terve Teemu !
You could buy a new complete clutch for 50,- Eur. from Reijo Roveharju. Unluckily it`s not very easy to contact him,`cause he doesn`t have a telephone. Keijo Virtanen or Olli Niinikangas could, perhaps, be of some help in contacting him.
Lykkyvä tykö!
Timo
(I hope I didn`t use too much dialects here.)
Fuhrpark: MZ ES 150 -66, CZ 516 Cross
MZ ETS 250 -72
JAWA 350 TS (638) + Velorex Sw -90
ISH Planeta Sport -75
MZ ETZ 250 "N" -88
Borgward Isabella -60
Lada-05
GM-03
FinnETS
Skype: maija_ja_timo
Re: ETZ clutch drag
Beitragvon Martin H. » 26. April 2009 09:09
Teemu hat geschrieben:edit. sorry I forgot, the springs were not renewed. Maybe they should have been?
That could be the problem; or maybe stronger springs.
The oil specification sounds o. k., I think it´s not the cause of your problem.
2015 Helfer
FBF-Papparazzo
Themen: 159
Re: ETZ clutch drag
Beitragvon engel » 16. Mai 2009 02:52
might it be worthwhile trying a lighter grade of oil and see if that helps? i run a product called motul transoil in all three of my two strokes boxes and have a mate with a similair bike in the case of the suzuki that tried a heavy gear oil and experienced drag as well. he changed it out and now has no problems.
initially i thought it may be a bit light but i use it in a dt200 thats knocking out 34ps through six narrow gearsets and it's been fine. th suzuki has 45 and seems to be ok with it also.
just a suggestion mind you as i don't imagine the 80/90 is al that fluid in the temperatures you're using it in in Finland(?) and a lighter may be of use. anyone else tried this stuff in europe able to confirm?
MZ in ost. fern, fern, fern ost.
ENGEL: ehrlich am anderer ende der erde.:angel:
"We're just two lost souls, swimmin in a fish bowl, year after year."
Fuhrpark: Marlene. es250/2 mit ts/1 kurbelgehause und getriebe. licht grun und minz turkis.
Issabelleh. yamaha DT200. jetzt ein "strand"ped
Lindie. 49 vincent rapide in kirsche schwarz.
Tinkerbell. 81 GSX1100 in Laverda orangen
Yardley.83 RD350 LC YPVS. red and flat black.
Anna. 82 GS1100G. duotone himmel und schlupfer blau metallic.
Anzyela. 87 CBR1000F, gelb/weiss/rot.
Katrin. 81 GS650G Katana.
gleich (gegen faulheit)wird ne K1 honda 750, CB400F, und 86GPZ900.
engel
Mitglieder in diesem Forum: Pedant und 23 Gäste
