Discbrake on my TS250/0
For non German-speakers. We will try to discuss in your language here, preferably in English. Guest posts welcome.
Beitragvon Lasse » 28. April 2010 08:41
Hi!
I am going to be putting on a discbrake on my TS250/0. I've bought a 16" frontwheel, and complete front-end from an ETZ. Now I thought it would be simple.
But then I saw this.
viewtopic.php?f=5&t=26216&start=50
Now my german is not that strong, but it got me thinking, do I need to fabricate something? Or is it a straight swap?
Regards,
Lasse
Fuhrpark: MZ ES250/2 1968
Yamaha XS650 1976
Lasse
Themen: 71
Re: Discbrake on my TS250/0
Beitragvon Ralle » 28. April 2010 09:00
Lasse hat geschrieben:I've bought a 16" frontwheel, and complete front-end from an ETZ.
2 questions: What is "complete frontend", the telescopic fork including upper and lower clamping head? The 16" frontweel was mounted into this telescopic fork with disk before you bought?
Ralle
FE1 - TS250 Käufer
Beitragvon guzzimk » 28. April 2010 10:05
Lasse hat geschrieben:Hi!
Regards,
Lasse
Hi Lasse,
please contact our member "trabimotorrad" (Achim), he does know how to do that !
Greetings
Markus
guzzimk
Themen: 48
Beitragvon trabimotorrad » 28. April 2010 10:28
Hi Lasse!
When you will montain a disc-break in a TS250/0, you have to change the 32mm fork into a 35mm one.
Then you can build in a 18" ETZ-front-wheel with disc brake. QWhen you hafe allready a 16"wheel with disc-brake, build in the wheel, the 3,5mm which MZ orded to put away from center, aren`t neccessarry.
I´ve don myself with a 18" front whell and driven for a long time, without any Problems.
-- Hinzugefügt: Mi Apr 28, 2010 11:52 --
Edith says: A ETZ-fork has its own problem: There ist a "nose" on the TS250-frame, where the ID-Number ist printed and which is neccessary for closing the bike. The ETZ fork will not fit. You mus take a TS-35mm-fork!!
Themen: 142
Beitragvon Lasse » 28. April 2010 13:12
trabimotorrad hat geschrieben:Hi Lasse!
The tripletrees won't fit? I don't need to be able to see the ID number.
By complete front-end I mean tripletrees, wheel, axle, stanchions and lowerlegs. The wheel and fork hasn't been mounted together before.
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon Marco » 28. April 2010 13:16
To solve the problem with the nose ther are 3 different ways:
1st
Go to your TÜV ingeneur (don't know how to say in another way) tell him the problem and ask him wheather it's possible to cut the nose and replace the ID on another place
2nd
Take a dremel or another tool an start to cut the nose. But don't cut to much. Cut so much that the ID is still viewable.
3rd
Mark the place where the lamp and the nose meet each other.
Take the lamp off. Take a small hammer and hammer on the small place where the nose an the lamp meet each other.
Mirinda 4 sale
Marco
Bilder: 79
Beitragvon Ralle » 28. April 2010 13:22
...& 4th way is to get trippletrees (is it the same i named clamping head :gruebel: ) from TS250/1, this could be te best way :idea:
Ralle
FE1 - TS250 Käufer
Beitragvon Lasse » 28. April 2010 13:23
Where can I find pictures of this "nose"? I can't imagine what it is.
It doesn't matter if the ID is viewable, I have registered the bike and don't need to do so again, according to the rules of Denmark :)
-- Hinzugefügt: 28. April 2010 14:25 --
Ralle hat geschrieben:...& 4th way is to get trippletrees (is it the same i named clamping head :gruebel: ) from TS250/1, this could be te best way :idea:
I think triple tree is the american expression :)
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon MaxNice » 28. April 2010 13:30
:gut: did so this week ;)
MaxNice
Mr. Flutschie (MoS2)
Beitragvon Ralle » 28. April 2010 13:33
"The nose" is the pice of frame, where the lock is get in if you are locking the bike.
@MaxNice: Bleibt die Funktion des Lenkerschloßes eigentlich mit den TS/1 Gabelbrücken erhalten oder nicht?
Zuletzt geändert von Ralle am 28. April 2010 13:49, insgesamt 1-mal geändert.
Ralle
FE1 - TS250 Käufer
Beitragvon Lasse » 28. April 2010 13:34
Ralle hat geschrieben:"The nose" is the pice of frame, where the lock ist get in if you are locking the bike.
So if I don't have the lock it would be no problem at all with the ETZ clamps?
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon Ralle » 28. April 2010 13:47
It only works with ETZ clamps if you cut of the nose from frame or use 3rd idea from mueboe
Ralle
FE1 - TS250 Käufer
Beitragvon Marco » 28. April 2010 13:53
I used the 2nd method and the TÜV ingeneur was delighted with.
Mirinda 4 sale
Marco
Bilder: 79
Beitragvon Lasse » 28. April 2010 18:14
I will be using an ETZ headlight, will that change anything?
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon Marco » 28. April 2010 18:34
Oh yes, if you take the ETZ headlight id should fit.
But i can't promise.
Mirinda 4 sale
Marco
Bilder: 79
Beitragvon MaxNice » 28. April 2010 19:14
Ralle hat geschrieben:"The nose" is the pice of frame, where the lock is get in if you are locking the bike.
natürlich bleibt sie das, ich habe beide brückenpaare zur auswahl gehabt und aufgrund des lenkerschlosses hab ich die TS/1 brücken genommen. der prüfer war mit dem schloss auch zufrieden und wollte kein extra mitgeführtes.
MaxNice
Beitragvon Lasse » 28. April 2010 19:48
MaxNice hat geschrieben:
Also du verwenden nur die TS250/1 brücke weil das lenkerschloss fungieren muss?
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon MaxNice » 28. April 2010 20:10
yes, thats why I use the TS/1 triple trees. you'll have another vantage if you use it too, because of your headlight. my is a ETZ type with welded TS mountings, so it might be used on both triple tree types, but i decided for TS/1 triple trees.
do it your way, it will be fine, if you have ETZ triple trees, use them and lock your bike with an external lock.
MaxNice
Beitragvon etzremo » 28. April 2010 20:14
Son Mist,ich kann kein englisch!
Gruß etzremo :roll:
Fuhrpark: SR2, Opel Zafira,Jawa 350, ,ETZ150,TS250
etzremo
Bilder: 46
Skype: TS Remo
Beitragvon Lasse » 28. April 2010 20:24
MaxNice hat geschrieben:yes, thats why I use the TS/1 triple trees. you'll have another vantage if you use it too, because of your headlight. my is a ETZ type with welded TS mountings, so it might be used on both triple tree types, but i decided for TS/1 triple trees.
An answer as clear as daylight, thank you!
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon MaxNice » 28. April 2010 20:35
etzremo hat geschrieben:Son Mist,ich kann kein englisch!
Gruß etzremo :roll:
ironie oder doch erklärungsbedarf?
"ja das ist der grund, warum ich die TS/1 brücken benutze. du hast noch einen weiteren vorteil, wegen deiner lampe. meine ist eine von der ETZ wit angeschweißten TS befestigungen, man könnte man sie an beiden brückentypen TS als auch ETZ befestigen. dennoch entschied ich mich für die TS/1 brücken.
bau es wie du denkst, es wird gut werden. wenn du ETZ brücken hast dann benutze sie und sichere dein motorrad mit einem lose mitgeführtem schloss (kettenschloss, etc)"
MaxNice
Beitragvon Lasse » 4. Mai 2010 19:29
Kann ich meine TS250/0 Lampenhaltern an die ETZ Brücke verwenden?
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon Marco » 4. Mai 2010 19:32
Das sollte gehen.
MZ schreibt bei Verwendung der ETZ Klemmköpfe aber das Kürzen der Lampendreiecke um jeweils 1 cm vor.
Mirinda 4 sale
Marco
Bilder: 79
Beitragvon Lasse » 4. Mai 2010 19:40
mueboe hat geschrieben:Das sollte gehen.
Will ein ETZ Scheinwerfer benutzen, will nur das Lampenhalter haben fürs Puig Scheibe haben.
Yamaha XS650 1976
Lasse
Themen: 71
Beitragvon MaxNice » 4. Mai 2010 20:10
Lasse hat geschrieben:Kann ich meine TS250/0 Lampenhaltern an die ETZ Brücke verwenden?
da wäre ich mir nicht so sicher, die standrohre sind ja dicker, wenn da noch 3mm platz sind gehts bestimmt.
MaxNice
Zurück zu Questions and Answers
